CT 200h Model (2011-2017)
TSB for brake booster and pump assemblies 2011-2013
Old Sep 13, 2021 | 05:11 PM
KKM's Avatar
KKM
Default TSB for brake booster and pump assemblies 2011-2013
Forgot to post this for 2011-2013 owners, in case you didn't get letter. This is for TSB 21LE01 in case you encounter DTC codes C1391, C1252, C1256, and C1253 or you get illuminated brake, ABS, or slip warning lights. They will replace the brake booster and brake booster pump assembly only if those pop up. Coverage is good until 11/30/22.
If the issue came up and you've already replaced them at your cost, they will reimburse you with submission of the proper paperwork.
Old Feb 11, 2022 | 09:13 AM
ljm1715's Avatar
ljm1715
no attachment?
Old Feb 14, 2022 | 02:39 PM
edgalang's Avatar
edgalang
Mine makes a farting noise all the time unless you feather the brake smoothly. No error codes though.
2013 with 142k miles.
Old Feb 15, 2022 | 07:49 AM
Raidin's Avatar
Raidin
Where did you see this? I had this happen ("fart" noises included), and am replacing the part. Mine might be due to mileage, but who knows.
Old Feb 16, 2022 | 08:46 AM
KKM's Avatar
KKM
Got the TSB through the mail:
Old Feb 25, 2022 | 02:11 PM
edgalang's Avatar
edgalang
Sucks that the TSB applies to my model year..and I experience the noise...but I have yet to get any error codes so I can't take it in. Hopefully, it will go before it expired in November of this year.
Old Jun 20, 2022 | 07:29 PM
r81984's Avatar
r81984
I have a 2011 CT200h and just got these two codes. My ABS, Brake, Slip lights all on. Recently, sometimes when I break the pedal will shudder. Brake fluid level is normal and there are no drips under the car.
I was troubleshooting thinking maybe one of the wheel speed sensors are bad, but they were all good and reading properly. I cleared the codes and drove about 5 miles and it did not return.
I googled this later and now see the TSB. I imagine it will come back on and I will try to get Lexus to fix it.
  • C1241 Low or High Power Supply Voltage
  • C1391 Abnormal Leak in Accumulator
I will say I think they had a bad issue with the brakes in the design and this is probably a side effect of many years of braking. Ever since I had this car it would skip while braking. It always would jump/skip during the transition from regen to physical braking at low speeds. It feels like the brakes just stop working for a second and then kick back in. It was scary at first but you got used to it and I posted originally about that but no one confirmed they had the same issue.
gadgets21
Hybrid Technology
Oct 15, 2018 08:02 PM
Hectorm
Feb 10, 2018 08:57 AM
Firas1
Hybrid Technology
May 26, 2017 06:43 AM
enigma65
GS - 1st Gen (1993-1997)
Dec 2, 2011 10:56 PM
Alaska
LX - 3rd Gen (2008-2021)
Nov 10, 2010 10:22 PM
