CT 200h Model (2011-2017)
Drivers mirror repair or replace?
Old Jun 23, 2020 | 04:42 PM
JCL2986's Avatar
JCL2986
Default Drivers mirror repair or replace?
can the outside/inside shell be replaced? Or does the entire mirror assembly have to be replaced? I saw a Lexus dealer on ebay sells the color matched outside and inside shell as a kit.
Old Jun 25, 2020 | 08:25 AM
E46CT's Avatar
E46CT
Looks like both your frame and shell are busted so you may as well get a complete assembly. Search ebay.
Old Jun 25, 2020 | 06:58 PM
JCL2986's Avatar
JCL2986
There are many of these kits on Ebay for 100. Is the black interior shell easily replaceable you think with this kit? it seems cheaper and easier than taking off the door panel.
Old Jun 25, 2020 | 07:00 PM
JCL2986's Avatar
JCL2986
There are many of these kits on Ebay for 100.00. Is the black shell easily changeable? It seems way easier than taking off the door panel and a used light is 200 plus.
This thread had me thinking its feasible.
https://www.ct200hforum.com/threads/...120354&slide=4
Old Jun 26, 2020 | 09:01 AM
E46CT's Avatar
E46CT
Oh yeah that's easy. Pop the glass w/ a flathead screwdriver by tilting mirror up with your hands first then you'll see inside where you can slot your screwdriver between the glass and the clips that hold it on--you may have white adhesive to deal with. just peel away. the glass will pop off but be connected by a wiring harness. (of course be careful so you don't break the glass) then use a correct size screwdriver (the screws are extremely tight) to pull away both mirror frame/cap. they fit together like a puzzle.
when you put back together, don't force anything. both halves should come together elegantly with almost zero resistance.
Old Jun 26, 2020 | 05:42 PM
JCL2986's Avatar
JCL2986
Thanks I appreciate the information! I will purchase the 100 dollar kit and be careful to follow the steps.
Old Jul 8, 2020 | 01:29 PM
JCL2986's Avatar
JCL2986
Thanks so much for your help and directions! Anyone that has a similar repair should buy this shell kit from Lexus vs an all new replacement and taking off the door panel. I owe you a drink if you are ever in south jersey. Took me 30 mins from start to finish.
Old Jul 9, 2020 | 09:52 AM
E46CT's Avatar
E46CT
Looks good! Glad it worked out for you. Now I know you can buy a kit and swap out the shells fairly inexpensively.
Old Jul 17, 2020 | 12:58 PM
nsxjohn's Avatar
nsxjohn
Incorrect Post
Conthodar
NX - 1st Gen (2015-2021)
15
Oct 24, 2025 11:40 AM
solar5000
Mar 11, 2014 03:11 PM
abbeyrd
Apr 29, 2009 03:31 AM
jimmit
RX - 1st Gen (1999-2003)
Nov 24, 2002 02:50 AM
