CT 200h Model (2011-2017)
Guide to remove the fog light? (2013)
Old Oct 26, 2019 | 10:52 AM
Jezo's Avatar
Jezo
Default Guide to remove the fog light? (2013)
Rock on the highway smashed out the glass on the fog light so I need to replace the entire housing. Does anyone have a guide or steps as to how to access the fog lights and be able to remove the entire unit from the car so I can put in a replacement? Both the glass and the light itself were destroyed.
Old Oct 26, 2019 | 10:12 PM
r81984's Avatar
r81984
I imagine it is the same as my 2011. I made this tutorial with pictures for swapping them out with LEDs. This will show you how to replace it. https://www.ct200hforum.com/threads/...ct200h.131202/
Old Oct 27, 2019 | 07:27 AM
spiral's Avatar
spiral
Same thing happened to me and I replaced mine at my last oil change (since I also do tire rotations at the same time). I just got the $20 replacements off amazon (Lexus quoted me $200 for 1 lens housing) and the fit was perfect without any modifications. The above procedure is spot on.
Old Oct 27, 2019 | 12:04 PM
Jezo's Avatar
Jezo
Oops, yeah I have a 2011, forgot that.
Okay so the guide, did you put the car up on a jack or if I get down there can I just pull the wheel well liner back and see the screws?
Old Oct 27, 2019 | 05:40 PM
spiral's Avatar
spiral
If you’re doing both lights, jack up the entire front end, if just one side it’s best to jack up that side. You /could/ do it without, but it really just makes it a lot harder and the extra time it requires along with hating yourself, you could have just jacked it up and removed the wheels.
removing the plastic undercarriage part is also much easier if it’s not sitting on your face.
Old Oct 28, 2019 | 03:44 AM
Jezo's Avatar
Jezo
Do you use a hydraulic jack? I still need to get one of those..
Old Oct 28, 2019 | 04:12 AM
spiral's Avatar
spiral
I use the Quickjack by Ranger. Prolly more than you’d want to spend to change the fog light
if you plan on doing a lot of maintenance on your vehicle(s), you should invest in a jack and jack stands. I’ll use the screw jack to get it started then switch over to a jack/stand all in one if just doing one side. Don’t forget to chock the rear wheels. You don’t want the car to roll on you.
Old Nov 2, 2019 | 06:32 AM
Jezo's Avatar
Jezo
I figured out how to get all the plastic bits out and have access to the assembly.
Before I order, this is the part I want? The other option is LED but I am not going that route, I just want to replace with a basic OEM style.
Rock Auto Link
Old May 8, 2025 | 08:53 AM
Jezo's Avatar
Jezo
Wanted to say thanks for this! I finally got around to replacing the light and this came in handy.
Took me a little while to get this done but it's complete, the light is working, and now I want to get one for the other side of the car because this one looks so much nicer!
(I don't know how to resize images so here they are below)
epi79
May 8, 2024 05:50 PM
Sheadninja
Dec 9, 2015 08:27 AM
Kingkrs
IS F (2008-2014)
Nov 7, 2013 04:41 PM
ebxgsxr
Sep 3, 2012 08:35 PM
Wald GS
GS - 1st Gen (1993-1997)
May 11, 2003 10:53 PM
