CT 200h Model (2011-2017)
Need to replace evaporator!!
Old May 7, 2019 | 04:21 PM
Red200's Avatar
Red200
Default Need to replace evaporator!!
Last summer the AC in my 2012 CT200h was kahootz. Took it to Lexus Dealership, they evac'd the lines and repumped with refrigerant, watched it and it lost 1lb overnight, they put in leak detector and couldn't find the leak, they said evaporator core. Price to replace evaporator is prohibitive right now because of getting to the dash innards.
I'm going to replace the evaporator myself in one of the apartment garages. I'm also going to replace the condenser since it's cheap and the expansion valve, and then I will take it to Lexus or Toyato to evacuate and repump with refrigerant. I live close to work so I can take the uber to the office relatively cheap.
Can anyone help me with information on taking apart the dash so I can replace the evaporator? Condenser and expansion valve are pretty straight forward, I just need help to figure out the evaporator!
Old May 8, 2019 | 09:49 PM
KKM's Avatar
KKM
Not sure where the evap is located but this shows how to get to the instrument cluster so maybe its a start that would lead you there.
Old May 9, 2019 | 07:59 AM
E46CT's Avatar
E46CT
Here's some dashboard pics that may help you. It looks as if though the dashboard lifts straight up via clips. i don't see any bolt holes there.
I'd also look at parts diagrams to get an idea too. looks like the upper half separates from the lower. don't know how much you have to remove... maybe look at Prius forums since the cars should be built pretty similarly and have a similar layout. i don't know it for sure but i'd suspect they use the same evap parts
If this helps, don't forget to hit the "like" button =)
Old May 13, 2019 | 01:52 PM
Red200's Avatar
Red200
Thank you for the information!
Luckily the heavens opened I was able to get complete torrent of Lexus CT200H Service Manual!
I will try to share the service manual through Google Drive here on the board!
Old Jun 6, 2019 | 12:16 AM
Red200's Avatar
Red200
I forgot to update this but I ended up successfully replacing the evaporator, expansion valve, and condenser. The evaporator was the most daunting task because of the difficulty in removing the air conditioning unit from out behind the dashboard structural bar. I honestly feel like an engine swap would have been easier than this just based on videos I have seen in the past on YouTube.
Lol.
If anyone is planning on replacing their evaporator at any point in time please feel free to shoot me a message because I have PLENTY of tips that I can share about the process.
Old Jun 6, 2019 | 12:14 PM
E46CT's Avatar
E46CT
^Pictures would probably help more than words. Post them if you got em =)
94_soarer
Aug 12, 2011 10:37 AM
94_soarer
Florida Lexus Club
Aug 2, 2011 05:56 PM
baltodano
IS - 1st Gen (2001-2005)
Dec 10, 2009 03:42 PM
1JZPWRD
Jun 8, 2009 08:06 AM
007
GS - 1st Gen (1993-1997)
May 14, 2007 10:15 PM
