CT 200h Model (2011-2017)
2012 CT200h Clock setting (with navigation)
Old Sep 29, 2018 | 05:10 AM
camiel76's Avatar
camiel76
Default 2012 CT200h Clock setting (with navigation)
I have a 2012 model CT with navigation ( 08 HDD version ).
Whatever settings I choose, I can't manually adjust the Clock time (hrs/minutes). The summertime / auto adjust clock can't be set to ON also anymore.
Does anyone have a clue on why this is the case? VIDEO link: https://streamable.com/s7fiz ( Dutch language but easy to understand 🙂 )
THANKS!
Old Oct 28, 2018 | 02:57 AM
camiel76's Avatar
camiel76
Anyone?
last night time changed to winter time over here. The menu won’t allow any changed to the daylightsaving and auto adjust time, both are fixed to OFF it seems ?
Help!
Old Oct 28, 2018 | 07:51 AM
lexusrus's Avatar
lexusrus
I thought time change WILL occur on November 4, 2018 which has not occurred yet..
Originally Posted by camiel76
Anyone?
Help!
Old Oct 28, 2018 | 08:35 AM
camiel76's Avatar
camiel76
Here in holland it’s today.. didn’t expect it to work anyways, the problem is still there 😏.
Old Oct 28, 2018 | 02:10 PM
lexusrus's Avatar
lexusrus
That is interesting.
I remembered I had to disable the daylight savings time feature and manually set the clock when the time change occurs. I know it is not "automatic".
Old Oct 28, 2018 | 11:06 PM
camiel76's Avatar
camiel76
that is exactly what I want to do, but pressing the + and - buttons gives no results. Either I am doing something wrong or it is a software thing and it needs some reset or anything...😌??
Old Nov 8, 2018 | 07:36 PM
tle99104's Avatar
tle99104
Have LS430 close to 10 yeras, just got a ls460-2013. try to adjust clock, but weird thing happened, Auto adjust which come up some wrong time. Go adjust manually, it's ok for that day only. Next day some wrong time again.
Try to set by gmt, but not last long. any help. thanks in advance.
Old Jul 30, 2020 | 05:24 AM
camiel76's Avatar
camiel76
Finally made some progress.
Found out about the hidden service menu, did the system check..
CLOCK —> NCON
So now I know it is a system fault.
I cleared the memory and did recheck.
It does not appear anymore as NCON.
Will it re-appear after a Memory Clear eventually?
Making appointment for NAVI update including repairing this Clock software error..
Stacey2447
LX - 3rd Gen (2008-2021)
17
Sep 25, 2019 06:41 PM
ross7777
NX - 1st Gen (2015-2021)
Jan 9, 2019 09:16 AM
Richardgil
Nov 5, 2018 06:41 PM
aps41
Sep 1, 2012 10:54 AM
Poison*Ivy
Aug 7, 2006 01:03 PM
