CT 200h Model (2011-2017)
Rear Camber Adjustment??
Old Feb 25, 2013 | 02:16 PM
kevinly89's Avatar
kevinly89
Default Rear Camber Adjustment??
Hi, I recentedly dropped my CT and I was wondering if anyone had any idea on how to adjust the rear camber? My driver side rear is -3.6 and my passenger rear is -2.3. I want to get wheels but I need my camber to be able to adjust before picking up a set of wheels.
Anyone with a dropped CT can help??
Old Feb 25, 2013 | 03:48 PM
m R g S r's Avatar
m R g S r
Why so much how much did you lower the car?
Old Feb 25, 2013 | 07:51 PM
m R g S r's Avatar
m R g S r
Anyway, from the manual:
"Camber is not adjustable. If the measurement is not within the specified range, inspect the suspension parts for damage and/or wear, and replace them if necessary."
This refers to the rear only. For the front check my other thread.
It also says;
Camber (Unloaded Vehicle):
-1.00 deg. +/- .75 deg
So technically a -1.75 camber angle on a stock vehicle is acceptable.
Old Feb 25, 2013 | 07:54 PM
kevinly89's Avatar
kevinly89
i have bc coilovers.
maxed out the front. rears are about 5 thread counts from max on the spring.
Old Feb 25, 2013 | 07:57 PM
m R g S r's Avatar
m R g S r
Got a pic of the car's ride height?
Old Feb 26, 2013 | 02:01 AM
chargerfan's Avatar
chargerfan
The manual Def says "rear camber is Not adjustable". Perhaps double check the coilovers for even drop/height to perhaps balance out that camber
I'm hoping sooner or later someone will make decent camber arms for our cars
Old May 2, 2015 | 12:10 AM
chargerfan's Avatar
chargerfan
back from the dead ...... REAR CAMBER ARMS ..... $219
http://www.meganracing.com/product.a...=1703&catid=91
Bocatrip
Feb 17, 2022 02:02 AM
EffSport
Suspension and Brakes
23
Feb 13, 2015 08:41 PM
menty
Sep 6, 2009 06:19 PM
ShaneC
May 15, 2006 09:05 AM
