CT 200h Model (2011-2017)
Lowest offset / widest wheels on ct....post away!
Old Nov 26, 2012 | 03:25 PM
m R g S r's Avatar
m R g S r
Default Lowest offset / widest wheels on ct....post away!
I posted this over on the ct200h forums but got very few replies.
I've now seen a few pics of low offset wide wheels on the ct. Please post up your fender mods, along with the wheel specs.
I have some f sport tridents coming for now but I'd really like some of the new work emotion Kiwami wheels....
17x9 +38. Concave face
http://forums.nasioc.com/forums/show....php?t=2361621
Thanks in advance!
Old Nov 27, 2012 | 08:11 AM
m R g S r's Avatar
m R g S r
http://www.ct200hforum.com/forum/lex...d-fenders.html
The thread i posted on ct forums
I saw another thread where someone with spacers and Tridents was essentially running 17x7 +11 and +21. So the x9 +45 would work. (outter Clarence, not positive on strut to inner wheel)
And the 17x9 +38's should work as well...,again depending on inner clearance. But as per another thread where someone was running 18x10's in the rear with -4deg camber, I'm pretty sure the 9" wide wheel will fit even with a lower (30ish mm) offset.
Old Dec 15, 2012 | 03:33 AM
Mitch08ISF's Avatar
Mitch08ISF
18x9 +38 off work emotion xd-9 no spacers with 265-35-18 on rears.
Old Dec 15, 2012 | 05:45 AM
m R g S r's Avatar
m R g S r
265's on this car? On the rear? For what? LoL
I had 275's out back on my 500whp s2000...
Old Dec 15, 2012 | 09:44 AM
Mitch08ISF's Avatar
Mitch08ISF
Fits really good, handles amazing and the whole stretch look on the back was way too much of a gamble on my nice rims. I needed to protect the lip from curbs as much as possible. I'll post some pics but it didn't change much excluding a proper fit and meaner look.
Old Dec 15, 2012 | 12:19 PM
m R g S r's Avatar
m R g S r
Alright looking forward to seeing it. Total weight wheel and tire combo?
Old Dec 15, 2012 | 12:26 PM
2013NGCT's Avatar
2013NGCT
Do the tires or rims stick out in the rear? Post some pics if you get the chance.
I'm thinking of going with Enkei Raijin, 18x8.5 front and 18x9.5 w/in the rear, both have 45 offset. With you running a 265/18 in the rear, there should be enough of room.
Old Dec 16, 2012 | 09:18 AM
Mitch08ISF's Avatar
Mitch08ISF
The lip of the rear rim is within mm of being perfectly flush with the body and the tires do not stick out at all. Last night was the first 15 miles on the set up. Full tank one passenger a few dips. No rubbing no hitting the rear fenders and the car feels glued on 65mph+ overpass turns. I should be able to post some good pics today. It fits almost exactly like my oem Isf wheels did with 285's on the rear. The weight can't be much more than what was already there but obviously additional.
Old Dec 16, 2012 | 02:50 PM
Mitch08ISF's Avatar
Mitch08ISF
Old Dec 16, 2012 | 08:36 PM
2013NGCT's Avatar
2013NGCT
Damn, that's a perfect fit!
Old Dec 24, 2012 | 01:29 PM
m R g S r's Avatar
m R g S r
New thoughts about getting Enkei Raijin
18x9.5 + 45 5x100
Concave face
I think the 8.5's are gross. Only like the concave faces, which starts at 9.5" widths.
Old Dec 24, 2012 | 02:17 PM
Mitch08ISF's Avatar
Mitch08ISF
18x9.5 + 45 5x100
Concave face
You gonna rock 9.5 all te way around? Size and offset Should work fine. You will be basically 12.5mm wider on the inside and outside of each rim compared to my set up, but your offset will be +7mm more going towards the brake assembly. Any other offset options?
Old Dec 24, 2012 | 07:18 PM
m R g S r's Avatar
m R g S r
Yeah no point in staggering the setup, I'm never going to track the car. Wheels would be strictly for looks.
The only off the shelf 5x100 x9.5 raijin is listed as 45 offset. I'm sure custom drilling can be done on lower offset wheels if they are ordered right from Enkei.
Yeah I'm willing to order and try out the combo with 245 tires. Don't wanna go too wide and add too much unsprung weight...
Old Dec 25, 2012 | 09:08 AM
m R g S r's Avatar
m R g S r
These are the concave 18x9.5 raijin. Not sure on offset, I think this is a pic of the +45
Old Dec 25, 2012 | 09:12 AM
m R g S r's Avatar
m R g S r
I'm pretty sure it would be 13mm closer on the inside. Can you grab a pic with the suspension compressed of the inner clearance on your setup?
