Looks good! At least you will be able to rotate unlike me. The plus on my set up is its so flush all the way around and 0 fender mods. I'm still on the fence on if I like the actual fronts sticking out like that.
mitch, how's the ride comfort with the full F sport set up? I just got the 2013 premium..and i don't want to sacrifice ride comfort. since i just got out of the 240sx scene lol
It is a little stiffer for sure but not as bad as a stock ISF in my opinion. The handling is absolutely amazing compared to a base ct for sure. But....I also have some super wide rear tires. This car stays planted to the road.
The ones above are 18x9.5 +38. X9 +35 will fit, but you'll probably need to roll the fenders, and maybe new camber bolts in the front to get a little negative camber. This depends on what tire size you want to run.
On the inner unrolled edge? Or the outter part?
Will rolling give it enough clearance? Or is a pull necessary (in order for the suspension to fully compress) to clear?
