CT 200h Model (2011-2017)
HID Kit Help
Old Jun 15, 2012 | 07:57 AM
  #91
xis's Avatar
xis
you might need a dedicated wire harness for your balast to make sure they are getting the correct power and not relying on the wires to the old lights to power your balast.
8000k? YUCK.
4300K?
Old Jun 17, 2012 | 06:49 PM
  #92
jerrsRX350's Avatar
jerrsRX350
I installed Kensun 5000k 35w as low beams a couple of weeks ago. Everything worked fine except I had to file down the light tabs so they would fit. I then ordered a second kit to do the fog lights. After a few days the drivers side light stopped working. Unexpectedly I received two new bulbs from Kensun? When I removed the light which wasn't working it had burned out. I replaced the bulb and the new bulb works most of the time. Once in awhile I get a bright yellow flash in the center of the headlight beam when the lights first come on. I plan to replace the ballast which could to be the problem? The passenger side light works all of the time in auto mode. If I was going to do this again I would use one of the more expensive kits ie Phillips. It's crazy to drive a car which may or may not have headlights to save a couple of hundred dollars. I've had HID's on all of my cars for over ten years. It never occurred to me that the CT200 had halogen lights! Buyer beware!
Old Jun 18, 2012 | 05:19 PM
  #93
jerrsRX350's Avatar
jerrsRX350
Originally Posted by jerrsRX350
I installed Kensun 5000k 35w as low beams a couple of weeks ago. Everything worked fine except I had to file down the light tabs so they would fit. I then ordered a second kit to do the fog lights. After a few days the drivers side light stopped working. Unexpectedly I received two new bulbs from Kensun? When I removed the light which wasn't working it had burned out. I replaced the bulb and the new bulb works most of the time. Once in awhile I get a bright yellow flash in the center of the headlight beam when the lights first come on. I plan to replace the ballast (purchased for the fog lights) which could to be the problem? The passenger side light works all of the time in auto mode. If I was going to do this again I would use one of the more expensive kits ie Phillips. It's crazy to drive a car which may or may not have headlights to save a couple of hundred dollars. I've had HID's on all of my cars for over ten years. It never occurred to me that the CT200 had halogen lights! Buyer beware!
The new ballast seems to be working OK. Both lights are OK. I'll have to get a new ballast to do my fog lights now.
Old Jun 19, 2012 | 05:43 AM
  #94
OutlawTita's Avatar
OutlawTita
After 4 months my Kensun 4300 have worked perfectly 100% of the time on Auto mode. Best $75 I ever spent on lights.
Old Jun 19, 2012 | 08:49 AM
  #95
jerrsRX350's Avatar
jerrsRX350
Hope you are right. I left my lights on all morning today and they worked perfectly. I ordered third kit to do the fog lights. No point in returning the faulty ballast or buying just a replacement ballast since the whole kit is less than $70 ...... one ballast costs $30. I'll end up with an extra ballast and three extra bulbs. I am also adding a third party plug-in connector for the bulbs ($1.99) to avoid the plug-in wire problem (tape, sodder?).
Old Jun 20, 2012 | 06:53 AM
  #96
OutlawTita's Avatar
OutlawTita
jerrsRX350.....let me know how that works out. I have been considering doing the fogs as well.
Old Jun 21, 2012 | 09:23 PM
  #97
jerrsRX350's Avatar
jerrsRX350
Low beams still OK. I leave them on full time to make sure they are working. I will get the kit with the new ballast next week and install the fogs. Expect the installation to be easier than the low beams?
Old Jul 1, 2012 | 08:24 AM
  #98
jerrsRX350's Avatar
jerrsRX350
Got the new Kensun kit for the fogs but the drivers side low beam HID failed again. The light failed to go on twice but is working OK today. I drove the car with the headlights on all the time for 10 days (not auto mode) without any problems. The passenger side has never failed so I'm sure the ballast is the problem. HIDs' are nice but I'm unwilling to risk light failure everytime I drive the car. Due to ballast failures, concern about electrical problems (warranty!), presence of squirrel spotters and the importance of having operating headlights I've decided to go with Phillips Crystal Vision Ultras halogen replacements for the low beams and the fogs.
Old Jul 2, 2012 | 06:26 AM
  #99
xis's Avatar
xis
or, just don't skimp on your HID upgrades with that Kensun crap.
You need a dedicated harnes from battery to ballast. If you think you can accurately power your ballast with the old wires to your halogens, you are wrong. You will most likely encounter the issues that you are experiencing.
look at the retrofit source... www.theretrofitsource.com
TRS
Morimoto
Old Jul 2, 2012 | 09:14 PM
  #100
yamaturkey's Avatar
yamaturkey
Thanks for updating!!so whats the price difference for phillip and kensun?
Old Jul 3, 2012 | 06:20 AM
  #101
OutlawTita's Avatar
OutlawTita
Maybe I was just lucky to get a good set from Kensun but after several months running on auto I have yet to have the first misfire and my HID lights have operated perfectly just as if they were installed at the factory. I couldn't be happier.
Old Jul 3, 2012 | 05:38 PM
  #102
jerrsRX350's Avatar
jerrsRX350
TRS
Morimoto
I am sure you are probably right. I have no prior experience installing HID's so I hoped that I would not experience problems ie like some others who installed Kensuns. I am willing to take some risks (warranty) but have reached my limit in making changes to the cars wiring. If the Halogens don't look/perform well enough I will consider a more expensive HID alternative. Thanks for your help.
Old Jul 3, 2012 | 05:41 PM
  #103
jerrsRX350's Avatar
jerrsRX350
The Phillips halogens were less than half the price of the Kensun kit.
Old Aug 14, 2012 | 07:30 PM
  #104
midcow3's Avatar
midcow3
Post Buy a more expensive HID conversion, better ballasts
8000k? YUCK.
4300K?
You don't need a dedicated wiring harness; that is not the problem. The old wires are fine and you will see absolutley no difference. However, there is a significant difference in the quality of ballasts and some of the lower cost HID ballasts, such as Kensun and DDM sometimes have problems. A good ballast provides enought current to fire the HIDs every time, and then limit the current as the arcs negative resistance is encountered. A very good brand that has beeen used by others without failure on the CT200Forum is H11: Morimoto Elite HID System $150.00 http://www.theretrofitsource.com/pro...oducts_id=3955
I personally have 6000k 35W Kensun and have not had any problems after almost a year's installation. I had some DDM HIDs installed but they failed a lot.
I agee 8000K does not look good, too purpleish. I like 6000K best because it ligths the road with a nice white glow. 4300K matches the DRL lEDs exactly, but gives the road a little yellowish -white glow.
Old Aug 14, 2012 | 07:32 PM
  #105
hookah66's Avatar
hookah66
thanx for posting and sharing with us, LxTxNx!!! ... I have noticed from your photos that the "squirrel spotters" effect is minimal, and I am pleased to know that after HID conversion you don't have the annoying bright spots.
PS: I have done one HID conversion on a 2010 Subaru Outback low beam headlights and did not use any relay harness; but for the fog lights on the same vehicle the relay harness seemed to help current stabilization. And remember higher Kelvin degree the lower lumens output you will get. So a 4300 Kelvin degree will have much higher lumens than the 6000 Kelvin degree bulb.
