CT 200h Model (2011-2017)
Replacement DIY for passenger rear window.
Old Nov 25, 2024 | 08:08 PM
memacman's Avatar
memacman
8th Gear
Default Replacement DIY for passenger rear window.
My son has a 2015 CT200h recently purchased. The passenger rear window sustained deep scratches. This will be a DIY repair. The question is where to find instructions on the removal of the glass and installation of the replacement glass?
Thanks all.
Old Nov 26, 2024 | 05:12 AM
morganc's Avatar
morganc
Depending on how deep they are, you could try polishing the glass with cerium oxide powder.
Otherwise, remove the door liner (rear is very similar to the front):
Then you'll simply have to plug the window controls back in and move the glass to a point where you can unbolt the glass panel from the regulator scissor assembly. Just be very careful when installing and aligning the new window, as you can inadvertently make contact with the scissor assembly and scratch things, again.
Also, the acousti-seal black sealant around the plastic vapour barrier is very messy; wear gloves/bad clothes and have someone help you...that or have masking tape ready to temporarily tape the vapour barrier out of the way while you're working.
This shouldn't be far off from the same procedure on the CT:
Old Nov 26, 2024 | 06:33 AM
memacman's Avatar
memacman
8th Gear
Thank for your suggestions, will certainly follow them. The damage to the window was (apparently) caused by a graffiti artist scratching deeply onto it a large and rough # sign onto it. Will look at the cerium oxide powder first. Though the amount of rubbing with the powder that’ll be required will leave its own unsightly “forget-me-not” marks after the repair. Now to find a Lexus Brand replacement window at a decent price. If not it’ll have to be a generic brand.
Thai435
Oct 30, 2024 06:54 PM
Nublex
Jan 23, 2023 03:00 PM
mowmow
Hybrid Technology
Jul 5, 2012 04:04 PM
flexthatdx
Jan 12, 2011 10:27 AM
rblancojr
Mar 14, 2010 06:03 PM
