Waste Gate Issues Tundra 2022
The OEM setup uses separators only. DI-only engines made good separators and very good OEM oil a necessity. Toyota is not the only company without major DI carbon buildup issues. The IS250 doesn't suffer from abnormal amounts of carbon buildup either. BMW engines past the N54 again don't really suffer from this... and so on, and so on.
Anyways, "Hot" V6s (assuming 90deg.) compromise on engine balance to make turbos serviceable. Not much of a fan. Hot V8 is very obviously a different story.
Can we just have the I6 back...
Oil is sent back to the pan and combustible gas is set to the air path in front of the turbos. Works better than a catch can in some ways since there is no risk of over fill and it has a huge amount of airflow/ability to separate vs most cans.
Really complex separators that send everything back to pan or to be burned depending on what it is/droplet size/density and are electronically controlled in some cases.
I replaced my 4.0s separator when I had the turbos off just since I was already in there and it is to an extent a consumable.....yeah not as worry free as a UZ engine but even the NA 1UR in my 460 also uses a similar system
Volkswagen has dual injection in Europe, but to my knowledge hasn't put it on any US-market cars.
I don't very much that any turbo V8 can be easier to work on than the 3UZ. The 3UZ is almost as simple to work on as GM LS engines, and with port injection and no EGR valve/pipe it does not need oil separators. There is no soot coming in, so whatever oil gets into the intake through the PCV just results in a clean, yellow oil coat, and not a greasy black gunk like most other engines.
The UZ also has coolant lines absolutely everywhere and they are all CT clamps, the Audi uses a distribution block that consolidated everything that tends to leak in one easy to get to place and anything up top uses quick releases. I can far more quickly and easily pull off the pump, T-stats, hoses etc from the Audi if I need to since it's all in the front left corner of the engine.
On the negative side plugs only last 20-30k miles so I guess it's good they made it so easy....
Literal ease of performing repairs is higher, spark plugs for example or intakes take much less effort and time. If you ever worked on a 3uz it can get annoying with how the harness is setup vs the Audi that is designed to "loom away" from you when working and the engine is mounted in a larger bay that massively improves access to everything. You can actually drop the exhaust without jacking the car up it's so easy, set it in high mode and you have full access and since it's hot V the downpipes are very easy to get to.
I believe you are confusing the 3UZ with the 1UZ. The original 1UZ was a total c-word to work on, with coolant lines everywhere, retarded clutch fan, retarded distributor design, cables, wires, and air and coolant hoses everywhere. The 3UZ improved on everything, spark plugs on it is 30 minute tops.
these engines use a hot V starter motor lol
Correct, and that starter is pretty only "difficult" job on the engine, and even then it pales compared to complete and utter clusterpluck of moderns motors.
I'm not saying the new stuff breaks less, I'm saying it's easier to deal with.
Mercedes/Audi/BMW don't do it probably because that carbon buildup won't be a major issue until sometime after the warranty is used up.
) are the 5th cylinder dust ingress - specifically on the 3rd gen GS300/450h due to the design of the air filter box. The 5th cylinder just so happens to be the fastest path for all the junk that can potentially come through the throttle body. Carbon buildup? Pretty much no discussions on that. Same with the ~2010 Merc V6 that introduced DI - way less issues across the board compared to the outgoing V6, despite being DI-only. On the other hand, you have the early BMW/VAG attempts...
greys0uled
Dec 16, 2021 11:40 PM
LexusLSLX
May 16, 2021 07:36 PM
ghoul
May 5, 2015 10:20 AM
