EV charging in the US is broken — can it be fixed?
EV tech is much more complicated when it comes to software/programming, they are not better in every way. I don't know of many ICE cars getting choked up with carbon, the IS250 had a lot of issues with its single DI system in its combustion chamber, some BMW's have had issues but most other cars/makes haven't. My ICE cars run just like new and have no issues with losing performance/efficiency. You buy too many unreliable BMW's if that is your experience.
Regarding software, both EVs and ICEs can run without any software, with purely mechanical components. You should research how complex the software for ICE engine and transmission management has gotten, and it's getting more and more complex to squeeze extra efficiency to comply with evermore stringent emission requirements. In the newest turbo motors the source code for just the engine management can have hundreds of thousands of variable. With upcoming US and Euro 7 emission standards, its only going to get worse.
And then you have so many other reasons why EVs are far superior. No need for emissions systems, no need for complex engine cooling systems, real world thermal efficiency of 30-40% vs 70%, easier to implement torque vectoring, instant torque, no real need for transmissions. Charging and battery tech are the only downfalls.
The one thing that concerns during all these EV discussions is how we are going to dispose the millions of wasted batteries from EV's in the future. As far as I know the batteries can't be recycled or repurposed.
Where are all the environmentalists, global warming people? Maybe I have missed it, does any one know here?
Are we going to incinerate them?, send them to outer space or bury them in landfills?
https://spectrum.ieee.org/energy/bat...ica-and-europe
Pretty much all DI engines get chocked up with carbon, unless they also have port injection, which adds to the complexity. Even worse for modern diesels, with their DEF systems and multiple EGRs. Then you have modern thin oil and lightweight pistons - all to squeeze an extra 1-2 mpg and the cost of longevity.
It's all complex now especially with all the complex systems/features automakers put in cars, people want though I question why we really need some of these systems and how useful they really are(lane keep assist, "self driving" , cylinder deactivation, needlessly complex audio/ent buried in touch screens, etc). I would prefer not to have all this nonsense adding cost, complexity, buried in screens, etc. I would rather have physical buttons and not as many useless features that can go wrong, many which are buried in touchscreen menu's. Stringent regulations will make everything worse, not better, and it solves nothing.
EV's have their own things they have to deal with, heat is one of them, batteries get very hot, they also need cooling/heat management design and measures but they are also very negatively effected by cold weather too. They also need to be designed to protect passengers from fire/explosions. One of the issues with Lithium batteries is how hot they burn and how difficult they are to put out when they burn, sometimes almost impossible to put out, you also have the weight they have to deal with and that will be a problem on our roads and bridges, it also leads to more tire wear/shorter tire life. More power plants, larger powerplants to charge EV's creates problems/more pollution, can be worse then what you get from a modern IC vehicle, there is what to do with all these big used batteries, you also have lithium and other rare earth element mining which is extremely destructive and dirty to the environment and all the charging infrastructure which is also expensive, destructive, resource heavy, etc. EV's just aren't solving anything of any significance and creating their own sets of problems which will likely be worse over IC engines. The main polluters are boats, big ships, aircraft, diesel work trucks, diesel 18 wheelers/hauling trucks, those are what need to be addressed pollution wise yet they won't with EV's because it simply can't be done or would be far too expensive and complex.
that is hilariously wrong.
the software controlling a modern ICE is hugely complex. as you've pointed out there can be MULTIPLE types of injection, there's flaps and controls for exhaust routing, cylinder deactivation, complex intake/exhaust valve timing algorithms, performance curves and modes, there's code for cold/warm starting and operation, etc.
regardless, i disagree with Och on cars getting choked up with carbon, overall it's a non-issue in the market.
With that being said, the current generation of ICE engines have probably peaked out. While new, they are the best they have ever been when it comes to power and efficiency, but in order to comply with future emissions we will likely lose 6 and 8 cylinder engines for good.
The fire and explosions apply to ICE's just as much if not more. But yeah, battery tech in its current state is the major issue holding back EVs. So while the EV drivetrain is far superior to ICE drivetrain, EV as a package in its current state it still loses out to ICEs for most purposes because of the battery shortcomings.
Not an issue for those who lease, once the vehicle gets a bit order there is a slew of issues. Valves get covered with carbon, restricting airflow and often not closing fully resulting in loss of compression. This reduces performance, efficiency and emissions. Also, high pressure injectors are far less reliable than traditional, and lose their efficiency as well. The only remedy for this to have both direct injection and port injection, and I don't know how many manufacturers besides Toyota actually do this, but soon they won't be able to even if they want to - port injection reduces efficiency and likely won't meet ridiculous Euro 7 requirements.
https://www.thesun.co.uk/motors/4721...to-extinguish/
https://coffeeordie.com/tesla-battery-fire/
Carbon buildup issues have absolutely not been resolved, if anything they are worse on turbocharged engine because of blow by. You're just not going to hear about it on a 3 year old engines as not enough carbon has been built up, but once they approaches 5 year 60k mark, they are choked up.
Arguing over gasoline fire vs lithium battery fire is like comparing gonorrhea to herpes, I have no idea which one is worse and don't care to find out.
What are examples of more modern engine designs(5 or 6 years old) that are still having carbon buildup issues from DI systems, still need the cleanings with walnut shells, etc? We know about the IS250, older Audi's, Fords, BMW's especially, and I think some Porsche's from 8-10+ years ago but what more modern designs still have the issues? I just don't think automakers would design/keep engines that had serious carbon buildup issues once they knew about it and will face lawsuits, angry customers, intervention from govt.
Battery components are extremely valuable and they are recycled.
