Should I do my timing belt or take my chances?
Old Jul 17, 2018 | 08:28 AM
MedicalDoc's Avatar
MedicalDoc
Originally Posted by Johnhav430
How about the rear diff and transfer case on your car....my uncle said we can DIY those on my wife's GM since we have a lift and the vehicle should be level (people on the 3rd gen LS forum seem to be ok with breaking this rule as they often use ramps). I know the general rule is to make sure you can open the fill plug prior to opening the drain plug, and her rear diff plugs looked awfully rusty at 74k. I think these things are 100k items, not positive. 90k is the rear diff on the LS430...oil is cheap...
Those plugs are soft as anything. When I changed the diff. oil, at around 100k miles, I had to get a new set because the Lexus tech stripped them when they did them at 40k miles. I used a power chisel to remove them. Just FYI that you may want to check them before you unscrew them.
MD
fastegg
24
Apr 19, 2017 03:34 AM
Davenlei
Mar 14, 2016 07:56 PM
carz2011
13
Apr 23, 2011 07:53 PM
pienomiko
Maintenance
Mar 10, 2009 06:48 PM
