Sorry might be a dumb question but i was wondering. Not entirely sure about the CVT in the hybrid Lexus models but a salesman told me that they dont have gears, like you know a 6 speed automatic. Well i see in the hybrid RX that it doesnt have a sequential shift, instead it has "D" and then after that a "B" i think. Well i see in the GS 450H and LS 600H that it has a sequential gearbox, why does it have one if it doesnt have gears in it? Is it something like you can just tap the lever up to go faster or something? Sorry really confused about this one, could someone explain it to me?
CVT can vary its gear ratios on the fly without shifting, it will feel like one gear the whole way, not positive on the technical workings exactly. But there are no shift points, powerband is uninterupted
A true CVT does not have stepped gears....it is essentially two opposing cone-shaped pullies with a belt between them, but you can give them so-called " gears " or driving ranges ". This, in a nutshell, is really done more with the final-drive unit than the transmission itself. The " gears" are actually two ( or more ) different final drive ratios, with the CVT working normaly through each.
Thanks AJ
well, RX400h does not have emulated gears? It is GS450h does that... they are really only emulated.
B in RX400h is for engine braking, which Hybrids dont have (its called coasting, and engine gets turned off).
GS450h also has two "gear ratios" that RX400h does not.
In lexus hybrids, it is really not an true cvt - it is power splitting device (engine/motors) that has planetary gearsets and works similar to cvt.
oh, well i have the concept of it a lil' but still confused, thanks for the input. why do u think they decided to make it different in the RX and the GS rather than making it the same unit, or such?
The RXh system is designed for more fuel economy than the GSh system, which is designed for more performance. The GSh system has a "torque multiplier" that the RXh system doesn't have.
In both systems the B or +/- positions turn on engine braking. The positions don'tt correspond to particular gears because there are no fixed gears. The positions are useful when going downhill when you want to slow down without being on the brake constantly. If you are not going downhill or wanting to slow down then there is no benefit to being in those simulated gear positions and it will only hurt fuel economy.
