Honda building a V-8?
Old Jul 28, 2005 | 09:29 PM
LexFather
Guest
Posts: n/a
Default Honda building a V-8?
"Honda is rumored to be testing a new aluminum-block V-8 n the Ridgeline pickup truck. The v-8 is in the 4.2-4.4 liter range with vtech and cylinder shutoff, and is slated to appear first the next Acura RL, a 2011 model launching in 2010. Honda also is adding the engine to the next generation Ridgeline slated for 2011 as a 2012 model. The exact configuration is unknown, but given the displacement, it's not based on the 60-degree 3.5-3.8-liter V-6s, so it's probably a 90-degree configuration, typical of eigh cylinder engines. Honda engineers take up the V-8 project as tehy complete work on a V-6 turbodiesel. It isn't designed just for the european market, which has embraced Honda's 2.2-liter disel four, but also would provide needed low-end torque for the ridgeline and pilot suv. Low sulfur fuel required in the U.S. from 2007 will make the engine viable and will launch about the same time as a Mercedes-Benz diesel assault on our market. Honda also is reportedly working on a hybrid-powered ridgeline for teh 2009 model year." - Motor Trend
So if it comes the first V-8 in sedans will be shared with a truck V-8 I wonder can they pull that off, I don't think anyone in the industry does that with a V-8.
We''ll see, its still a good 5 years away.
Old Jul 28, 2005 | 09:42 PM
AJ's Avatar
AJ
CL Folding 10,000
Guess honda wants a piece of the V8 action
Old Jul 28, 2005 | 10:05 PM
nthach's Avatar
nthach
too bad it would suffer a lack of torque...
Old Jul 28, 2005 | 11:11 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
if im not mistaken then the Tundra (truck) shares a V8 with most of the early Lexus V-8 models....
Old Jul 29, 2005 | 12:15 AM
Vegassc400's Avatar
Vegassc400
The Tundra has a totally different engine. The 2UZ FE is in the Tundra, Pathfinder, GX470, LX470 and Sequoia. The 1UZ is in the SC, GS and LS400. The 3UZ FE is in the GS, SC and LS430. Although the 1 and 2UZ do share some similarities, they are different.
Old Jul 29, 2005 | 01:57 AM
CK6Speed's Avatar
CK6Speed
I mentioned Honda was testing the V8 in the Ridgeline and that it probably could find its way in the RL a few weeks ago in some of the other topics. Sharing the base engine design between trucks and cars is no bid deal. The cams, will be different, tuning will be different. Its the same as how the MDX engine responds totally different from the RL engine even if they are both J spec 3.5L engines. If it works it works.
Old Jul 29, 2005 | 08:16 AM
What's wrong with that? For pickups in particular you need a V8 to tow anything beyond a jet ski.
Old Jul 29, 2005 | 08:17 AM
Why do you say that?
Old Jul 29, 2005 | 08:41 AM
Leets's Avatar
Leets
sorry to be ****, but... it's VTEC... VTech is a phone.
I'm not surprised that they're considering V8s. Considering their popularity in high-dollar markets (namely the U.S.) it was only a matter of time before Honda joined the crowd. I wouldn't be surprised if they only had one engine family for the V8 and used it in several different platforms. I doubt they'll be identical between platforms, but they'll still most likely be derived from the same family. It's basically the same thing GM does with their small blocks and Honda did with the Accord/S2000 motors and all K-series motors.
Old Jul 29, 2005 | 02:40 PM
Koma's Avatar
Koma
CL Folding 25,000
Ha! Nissan had to borrow our engine?
Old Jul 29, 2005 | 04:14 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
He thought he was that slick, and tried to slip one right past our Radar, but no way... not on CL my friend.
Old Jul 30, 2005 | 12:07 PM
Celicamaro's Avatar
Celicamaro
When Honda does come out with a V8, it will make all other stock V8s of similar displacement look shameful. Lets hope they put it in a vehicle that is not heavier than the competition.
Old Jul 30, 2005 | 12:14 PM
videcormeum's Avatar
videcormeum
The "Hemi" 5.7 liter is found in both Dodge's trucks and the Chrysler/Dodge 300c/Charger.
M.
Old Jul 30, 2005 | 12:50 PM
AlwaysLate's Avatar
AlwaysLate
Mercedes-Benz uses the same V8 that they use in the E500, CLK500, S500, CLS500, CL500 and SL500 in both there ML500 and G500 trucks.
I believe BMW also uses the same 4.4 liter V8 that they use in the 545, 745 and 645 in the X5.
Old Jul 30, 2005 | 02:05 PM
GFerg's Avatar
GFerg
Speaks French in Russian
CL Folding 25,000
Bout time. Looking forward to it.
jwong77
Dec 21, 2010 09:05 PM
UDel
Sep 4, 2010 08:49 AM
LexFather
Feb 8, 2010 12:26 PM
