ARP 2000 bolts, use engine oil instead?
Old Sep 3, 2023 | 04:10 PM
PEPSI's Avatar
PEPSI
Post ARP 2000 bolts, use engine oil instead?
So I'm just wondering about my connecting rod cap bolts which are ARP 2000 bolts. I used 5W30 engine oil instead of ARP lube, I had ARP Lube but I forgotten due to reading toyotas instructions. So I used engine oil, I will admit that when I was torquing the bolts down it wasn't going down after 60 ft lb smoothly. How ever I did 4 increments of 20 ft lb to 80 ft lb.
I was just wondering if this would mess anything up?
Should I send it? Or should I take it apart?
Has anyone ever done this? If so did it go well or bad?
I tried multiple ways to find out this answer however never got an answer directly.
Old Sep 3, 2023 | 04:12 PM
What engine are we talking about?
Old Sep 3, 2023 | 04:44 PM
You badly messed up. You MUST use ARP lube, anything else is not what they spec and unless you used a stretch measurement of the fasteners it is not correct at all. Take it apart, check the fasteners for deformation and redo it with the correct lube making sure to get it under the heads as well, they want everything that moves to be covered in the stuff.
I've built many modified engines and if you are using a non-OE fasteners you must follow what they say to do, I also hope you have the rods resized with the new hardware or you may have an out of round situation since ARP hardware has 200-400% increased clamp load over stock in some cases. You should always have the big ends checked regardless, doubly so if you are altering spec
Old Sep 3, 2023 | 05:43 PM
PEPSI's Avatar
PEPSI
Exclamation Ok thank you
Thank you for letting me know so soon! Do you think that my bolts might be bad if I take them off and reinstall with ARP Lube?
Old Sep 3, 2023 | 07:32 PM
I'm honestly not sure, I would measure them against a new one at least. I've never tested that
Old Sep 4, 2023 | 10:10 AM
Margate330's Avatar
Margate330
Ya'll are more brave than me. Lol
Rebuilding engines is hard core and you get one shot at it and if wrong, have to start over.
Old Sep 4, 2023 | 01:37 PM
PEPSI's Avatar
PEPSI
Talking
Good news, there bolts somehow survived! I put ARP Lube on them. I noticed that the motor was easier to turn after putting correct Lube in. So long story short bolts will survive the mistake and to take it apart and put the Lube on.
Old Sep 4, 2023 | 01:47 PM
jwong77's Avatar
jwong77
IS that a 2JZ that you're rebuilding there?
Old Sep 4, 2023 | 02:14 PM
bkowa092's Avatar
bkowa092
I'm with you. I wouldn't trust myself to not skip a step, similar to the OP, and see all that money just go up in flames (literally). Glad to see the OP caught his mistake before any major damage was done.
Old Sep 4, 2023 | 03:17 PM
PEPSI's Avatar
PEPSI
Yep sure is!
Old Sep 4, 2023 | 09:46 PM
Margate330's Avatar
Margate330
Yep sure is!
Well, hell!
Post up some pics so we can see your work if ya feel like it.
Share the wealth. Lol
Old Sep 5, 2023 | 12:49 AM
PEPSI's Avatar
PEPSI
Well, hell!
Painted the block
Almost done
Not wealthy by no means 😂
Vtallysx4
Aug 18, 2021 02:07 PM
Alokat007
Dec 10, 2017 08:46 AM
dyuanda
Jul 14, 2016 12:46 AM
eloyc02gs3
Dec 2, 2012 07:23 PM
