Canada For events in Canada.
SPOTTED! In Vancouver...
Old Mar 2, 2012 | 11:41 PM
  #3106
IceIridium's Avatar
IceIridium
Any Vancouverites know?....
Any GVRD dealers willing to turn off DRL's? I'm getting the 2012 headlights so I need to get my DRL's turned off.
Old Mar 3, 2012 | 02:25 AM
  #3107
Sango's Avatar
Sango
There is a chance that you may not be able to turn off the DRL if it is a Canadian car. According to Jeff Lange for his 2011 ISx50, the feature to turn off DRL was not showing up in Techstream. Probably switching out the ECU which controls it for US one which does have the feature can do the trick.
Old Mar 8, 2012 | 06:14 PM
  #3108
narfy's Avatar
narfy
i don't have an EPC handy, or any reference material for that matter, and i know jeff, and he knows his stuff... but is there no daytime running light resistor in newer cars?? on most cars with a DRL resistor, it's as easy as unplugging it...
Old Mar 13, 2012 | 11:04 PM
  #3109
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Most of the newer Lexus (and Toyota for that matter) models use a duty cycle type DRL function (controlled by the front controller in the MPX ECU in Lexus models), a timer chip and 2 transistors run the high beam bulbs at 50% duty cycle at 12V, instead of a resistor. The body ECU sends the MPX ECU a signal over the BUS to enable the DRL function. In USA models, the body ECU allows this to be disabled, in Canadian models this is not possible. There are 3 good ways I can think of to disable DRL in newer Canadian duty-cycle function cars: get a USA body ECU and use a Techstream to disable DRL, get an MPX ECU without the DRL circuitry (transistors/timer circuits -- there are 2 of these for the 2IS, the overseas one without DRL, or the 2011+ one with LED DRL's as these turn on the LED's instead of the high beams), and finally adding a relay to the high beam bulb so that it only completes the high beam bulb circuit when the low beam is on, which effectively disables the DRL as well. The last method was what I used for my car.
I tried to open up the MPX ECU to remove the timer circuit, but it was quite impossible without damage. It was very glued, haha. I also contemplated getting the correct MPX ECU, but I had relays lying around, so I just did it that way. I may still do that one day, we'll see.
Jeff
Old Mar 14, 2012 | 11:22 PM
  #3110
TCKeyz's Avatar
TCKeyz
Spotted a white 2IS with yellow fogs and black "roof spoiler?" on Hwy 1 at around 6pm, we drove the same way all the way from burnaby to Mary Bypass then I lost him. I was driving in a black GS450h that is needing a wash haha
Old Mar 15, 2012 | 01:22 AM
  #3111
Mr.JPG's Avatar
I think thats me you saw this evening, I'm heading to my parents place.
Your car looks dark grey to me
Old Mar 15, 2012 | 02:40 AM
  #3112
TCKeyz's Avatar
TCKeyz
Haha damn thats how dirty my car is... black cars are impossible to keep clean, I wash my car weekly too I guess I will give it a wash tomorrow in the rain
btw your yellow fogs are really sharp, I was starring at it all the time when you were behind me
Old Mar 15, 2012 | 12:32 PM
  #3113
Stormforge's Avatar
Stormforge
executive matchup
we need to have a GS meet...i know a few other guys with 3GS in lower mainland.
Old Mar 15, 2012 | 01:39 PM
  #3114
TCKeyz's Avatar
TCKeyz
+1 , I would love to meet up with you guys its so rare to see 3GS around here!
Old Mar 15, 2012 | 07:22 PM
  #3115
Stormforge's Avatar
Stormforge
executive matchup
i'm thinking about organizing a 3GS meet in a few weeks. which day works best for you - saturday or sunday afternoons?
Old Mar 15, 2012 | 08:18 PM
  #3116
TCKeyz's Avatar
TCKeyz
Saturdays would be perfect, I'm always busy on Sundays.
Old Mar 15, 2012 | 08:30 PM
  #3117
Stormforge's Avatar
Stormforge
executive matchup
i've pmed two guys: 604GSh & envious. hopefully they will post here and let us know their if saturday works for them....
Old Mar 15, 2012 | 09:47 PM
  #3118
604GSh's Avatar
604GSh
Sunday afternoon is better for me. Some sat I'm ok. So just set a day and I will work around it.
Old Mar 16, 2012 | 07:55 AM
  #3119
moky's Avatar
moky
stormforge, can 4gs guys join too?
Old Mar 16, 2012 | 09:53 AM
  #3120
TCKeyz's Avatar
TCKeyz
You 4GS guys will make us too jealous haha but I will let Stormforge comment on that one, personally I have not been able to see a 4GS in person and it would be awesome if I can see one close up
