Build Threads Details on Club Lexus 2IS owner vehicles
Lexus is220d engine swap options
Old May 17, 2022 | 07:05 AM
jurisals's Avatar
jurisals
1st Gear
Default Lexus is220d engine swap options
Hello! I have ran into a problem with My 2.2 diesel engine. The engine lost compression and needs to be replaced. I want to know how hard it would be and what parts should be replaced and which ones can stay when swapping a 2.5 engine that is also from a 2is. Or mabye there are other toyota diesel engines that can be easily fitted and are more reliable than the original one. If not, i will just have to stick with the original 2.2 engine swap.P.S. when I bought the car I didn't know that the diesel model had all those engine problems that everyone seems to be having. Now I know 😁.Thanks! Juris
Here's a picture of my car
Old May 18, 2022 | 02:47 PM
2013FSport's Avatar
2013FSport
As these cars were never released in the US, few here in the us have any experience with these so try not to get discouraged. What other problems have you had?
You best bet might be buying damaged gas powered 2IS and moving everything over. I can't imagine it is worth all the work tho vs fixing yours.
Option 2 is to go through the parts list on your build vs the gas version and see what all is different. I suspect it is a very long list that starts at the radiator and ends at the drive shaft to diff covering everything in between.
GL
Jwconeil
IS F (2008-2014)
Feb 27, 2025 08:13 AM
Clynch7743
Dec 25, 2019 07:00 PM
Tserna76
RX - 1st Gen (1999-2003)
Oct 27, 2017 08:56 AM
Arnoldg
Oct 29, 2015 04:33 PM
manish1607
Aug 30, 2015 04:59 PM
