A custom monster
A custom monster
Hey everyone
I'm new here to the club and have used the website for help many times
I got a 95 SC400
Customized by the previous owner
its has 5 spd AT and I believe a diff engine as well.
She goes 0-60 in 6.1 sec and thats not stock
I just did the front end suspension top to bottom
Tracks and rides well
I love this car
I have sone questions that I'm desperate yo hear answers for...
... I'm having idle issues, she gets rough and almost dies and/or just dies, not ever when driving unless it's low speed(20-30 mph) never at high speeds
it's got an iac delete and a floating EGR
the esv and vsv are disconnected
and idle is affecting or is affected in such a way that my needles for speed and rpm start to perform their own light show
this is my first time posting I've owned this car for less than a year and have fallen in love with her lol
I'm ordering a wide body kit and taking this monster past the heights of 700hp
(WOO!)
NEED AS MUCH 8NFO AND HELP AS POSSIBLE
THANKS A LOT
I got a 95 SC400
I love this car
(WOO!)
THANKS A LOT
If your instrument cluster light show coincides with the idle/running issue, I'd say its an electrical problem.
Is it random? Or does it happen during similar conditions?
Look for loose electrical connections, bad grounds...
port snd polish Everything I can
weight reduction at least 500-600 lbs
twin 5pb turbos for top end
blown or supercharged (not sure yet)
serious suspension
And most of all, precise gearing i might do a ford 9in in rear or tundra str8 axle
WOOO!
AND fixed pwrstrg leak/kinked line and got rid of air in system
NO MORE hick ups or dYing
gonna remove hyd fan and pump after finding pressure cracks in t Stat housing
New fluid, thermostat, thermostat housing, and electronic fans
I want trans cooler lines to be a fixed pair of heat eliminating lines and if I can install similar lines on any other hot liquid running components I will
will finish egr delete and o forgot to mention, she has a 5 spd AT and yes, it's a 95 and 9.5 is target time to beat
(neighbor across the street has a solid steel body 3800 lb 9.5 second 69 Nova 640 horse all motor)
need some good cold air intake suggestions too
stage 1: weight reduction (fiberglass hood & trunk abs/trac delete ,replace rear pass wind with plexiglass and shock tower braces front n rear , new fuel pump, off to the strip
serious suspension
WOOO!
