Build Threads Details on Club Lexus 2IS owner vehicles
Aspect's 07 IS250 AWD
Old Mar 31, 2018 | 08:44 PM
  #91
Nespo2330's Avatar
Nespo2330
Originally Posted by Aspect
Lowered again and the lip is on. Leveled the coilovers again to make sure its all 25" ground to fender
How long have you had the coilovers and do you always ride 25” to ground in the summer? How do your CV boots look?
Old Mar 31, 2018 | 10:21 PM
  #92
Aspect's Avatar
Aspect
Well I've been approx 25" since I got my BC racing coilovers 2 summers ago, it's just that last season I saw that the passenger side was sagging a bit which made me check the heights for this season before I get too lazy. CV boots are in pretty good shape, one might be leaking a little bit but not in a state of worrying about it. I replaced a CV axle in the past but that was due to unrelated winter fun and unexpected curbs :P
Old Apr 3, 2018 | 07:53 AM
  #93
rk1zle's Avatar
rk1zle
how have your headlights lasted in Canadian winters before the retrofit? Any noticeable condensation?
Old Apr 3, 2018 | 11:41 AM
  #94
Aspect's Avatar
Aspect
both my stock headlights and spec d lights have had no condensation issues since I've owned them except for one time where I didn't seal the cover properly so that was on me
Old Apr 10, 2018 | 03:16 PM
  #95
Aspect's Avatar
Aspect
Figs toe links done... 10 years of rust on the old cam bolts and nuts took its time
Old Apr 10, 2018 | 04:29 PM
  #96
Nespo2330's Avatar
Nespo2330
A leaking CV Boot is never a good thing 🤔 that is definitely something worry about. If it were the clamp
ok, but leaking never means good...
Old Apr 10, 2018 | 04:37 PM
  #97
Aspect's Avatar
Aspect
Well I've cleaned up the area since and it doesn't seem to be leaking right now so all good
no symptoms of a bad CV axle yet.
Old Apr 11, 2018 | 06:45 PM
  #98
Aspect's Avatar
Aspect
Got my alignment done today.
Front L/R
Camber -1.7/-1.5
Toe -0.05/-0.05
Rear L/R
Camber -1.9/-2.0
Toe +0.1/+0.1
I don't know much about alignment specs, but I definitely feel like the car tracks even straighter than before because of the finer alignment with the adjustable arms.
Old Apr 12, 2018 | 10:04 AM
  #99
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
In Ontario, these may possibly be the worst option to replace the factory arms with. Especially with how much salt is used on the roads, as evidenced by what your old arms and hardware looked like. The FIGS links use an unprotected spherical bearing, once grit and grime get in there and wear away the coatings and those things start to rust, they will seize up pretty good.
Unless the car will only be driven in the summer from now on, or you plan on inspecting those joints periodically, I'd maybe look for something that has a protected joint.
Just my opinion though, I'm sure they'll work great for now.
Jeff
Old Apr 12, 2018 | 12:58 PM
  #100
Aspect's Avatar
Aspect
Jeff
Honestly I had the same opinion, but talking with Mike? at FIGS he told me that I should still go without the rubber boots. In hindsight maybe I should have went with my gut and got the booted version. We'll see what'll happen in the winter lol, I might try to rig up a water resistant cover over it for the winter. Not sure how many more years I'll keep the car for but it should last until the end of my ownership
Old Apr 13, 2018 | 04:52 PM
  #101
Aspect's Avatar
Aspect
ARP extended studs and 20mm H&R spacer installed in the rear, looking forward to testing fitment with my Enkeis
Old Apr 15, 2018 | 01:29 PM
  #102
Rise's Avatar
Rise
Default Did you notice a difference with spark pluga
Did you notice a difference with the iridium spark plugs
Got new spark plugs after finding out through flowrider that the eBay plugs were pretty likely counterfeit. Also got a new lip in the mail today, and I'll apologize to CL that I've joined the dark side and got an eBay replica lip(Wald rep I think). I know the bad rep about replica lip fitment and the ethics of it but I couldn't justify spending 1k on a lip.
just quickly put it up against the bumper to see how it'd look.
Old Apr 15, 2018 | 02:55 PM
  #103
Aspect's Avatar
Aspect
Could it placebo but at first it felt like it had more pep and go. Over time it just feels normal and runs great, no complaints. MPG is still about the same as well. They were cheaper than the dealership OEM plugs too which was a plus. If you're considering them I'd recommend them.
Old May 4, 2018 | 07:13 AM
  #104
Aspect's Avatar
Aspect
Everything finally together in a pic. Not sure what I want to do now, but this will be how it is for a while. Took so long to do a spring update because the wheel shop took 4 weeks to refinish my wheels, not that they were that badly damaged, maybe just busy, but I had to get 3 wheels straightened. Good ol' potholes
On a side note, I finally fixed a creaking and popping sound in the front end. Seems like I didn't install one of the subframe bolts properly and almost crossthreaded the entire thing >< which ended up being a little loose even when tightened all the way.
Old May 14, 2018 | 01:25 PM
  #105
Aspect's Avatar
Aspect
First wax of the season. Switched from mother's to Meguiars carnuba and I think it looks a lot better. Also did a quick engine detail, prob the first in my cars life.
Also emptied out my oil catch can and witnessed more of the disgusting oil and sludge that it collects.
Im liking the rear spacers a lot. Like the wider rear look and it also has turned my under steer at the limit to over steer =D
My wheels don't seem to shine as much as before. I think the shop messed up and painted my wheels brilliant silver instead of hyper silver cause its lacking the chrome ish look.
