sc400 w58 2jzgte swap in progress
yeah I understand the is300 has a 2jz, it also has a w55 trans that is not the same as a w58 trans.
they are 2 different W series transmissions for a sc you want the w58, but maybe the 55 could work I am not familiar with that swap.
yeah, i would assume the shifter location on that w55 is not the same as a w58 at the least, and that you would probably need the cradle from a w58 out of a mk4 supra or sc if it will even bolt up.
also the w55 is known to break on even non boosted is300's I wouldn't waste my time, you should get an r154 or at least the w58.
When replacing manual trans its a little more to go r154 but you won't have to do it again when that W breaks.
If you already have a W in the car, then rock it until it goes, but if you have to spend money to make something reliable r154 is the place to start or a v160 if you want to go all out.
https://www.clublexus.com/forums/per...-an-sc300.html
Thanks 805 and yea I want a r154 or v160 gotta save just want the car up and running.
It will bolt up Cuz its the same bell housing I hear mix things about the strength of these transmission ....I don't plan on making big power on this trans the clutch wouldn't hold up any way I was just wondering about the shifter which I recently found my answer so I m OK on that ....if you guys no anybody with a shifter that would be a great help
Anything is possible. I am sure you can get anything to work in our cars with enough funds. I also didnt know that abou the IS300 tranny being so weak. I am rocking the R154 out of a Soarer. Good luck on your build and post alot of pictures.
Also look how they went back to the older type of shifter that looks like the older w58's and r154's before they got the remote shifter cage that on all of toyota's "nice" transmissions. I take it as a sign of they just slapped something in there that would work, and that is was not "over-built", but this is just my opinion the only facts are that people are breaking them often.
