Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Paint correction
Old May 29, 2017 | 06:20 PM
Jenesh14's Avatar
Jenesh14
Default Paint correction
I was using goo gone to take of some glue because I debadged my car but what I didn't know is microfiber cloths and goo gone didn't mix well. I didn't know till it was too late but the microfiber cloth burned onto my paint and now I have a big orange stain at the bottom corner of my trunk. I've tried washing it off, using a clay bar, and I just tried some meguiars rubbing compound (hand polished the stain)on it. The clay bar helped a little and the rubbing compound didn't make a difference. If anyone has a suggestion on how I can get the stain off that would be great. I really don't want to repaint the entire trunk because of a dumb mistake...
Old May 29, 2017 | 07:05 PM
jtrue28's Avatar
jtrue28
You may need to wet sand it. If you've never sanded, or don't have all the necessary tools, take it to a professional.
What color is your car? Do you have a dual-action polisher?
Old May 30, 2017 | 12:37 PM
lovemyGSFS's Avatar
lovemyGSFS
That sucks i would just take to body shop and see if they get it out
Old May 30, 2017 | 04:35 PM
e60bmw's Avatar
e60bmw
Got a pic?
Old May 31, 2017 | 07:34 AM
Jenesh14's Avatar
Jenesh14
my car is star fire white pearl and I'd probably go to a professional
Old May 31, 2017 | 07:49 AM
Jenesh14's Avatar
Jenesh14
Originally Posted by e60bmw
Got a pic?
Old May 31, 2017 | 07:45 PM
kiddough's Avatar
kiddough
that will buff right out
Old Jun 1, 2017 | 08:58 AM
bclexus's Avatar
bclexus
Try this:
Seriously!
Old Jun 1, 2017 | 01:25 PM
Jenesh14's Avatar
Jenesh14
Originally Posted by bclexus
Try this:
Seriously!
is it safe on paint? Seems kinda sketchy to me
Old Jun 1, 2017 | 03:43 PM
bclexus's Avatar
bclexus
This OxiClean is a gel, which is perfect to apply to your car's finish. Just apply and let it work - no rubbing (friction) is necessary. If you are not familar with OxiClean, you should research it. It is used to remove grass stains, grease stains, blood stains (which are the worse) and a number of other extremely hard to remove stains. Football, baseball, soccer uniforms with ground-in grass and dirt stains, blood, etc. is no problem for OxiClean. It is even safe for the most delicate fabrics to remove all different kind of stains, from grease to dried blood, without causing any damage whatsoever. It will not hurt your paint finish. You may have to leave it on for a number of hours.
Old Jun 1, 2017 | 03:53 PM
Jenesh14's Avatar
Jenesh14
have you tried it beofre I just don't want to risk it. Oxi is like a bleach wouldn't it cause the paint and metal to corrode in any way?
Old Jun 1, 2017 | 04:36 PM
bclexus's Avatar
bclexus
No, it is not a bleach! Jenesh - Research it yourself!
There are NO harsh chemical ingredients in OxiClean. OxiClean is made up of Sodium Percarbonate (Na2CO. H2O2) and Hydrogen Peroxide (H2O2). It's as safe as applying Dawn soap (very different than OxiClean), which is used to clean wildlife.
Old Jun 1, 2017 | 05:00 PM
Jenesh14's Avatar
Jenesh14
im actually going to go ahead and buy some on my way home is there any special procedure since I'm putting it on a car and not cloths
Old Jun 1, 2017 | 05:10 PM
bclexus's Avatar
bclexus
If you buy the Gel Stick (image above) you will just dab it on and wipe it (with your hand/fingers is fine) to cover the area. No application force is necessary. After a while it will dry, but the process will still be working. I would allow it to sit for a day or two before easily washing off with water.
Old Jun 1, 2017 | 05:29 PM
Jenesh14's Avatar
Jenesh14
thank you I hope this works, spent too much trying to fix this issue
