ABS after 1jz swap
Old Oct 30, 2009 | 01:14 PM
BigGreen's Avatar
BigGreen
Default ABS after 1jz swap
Hey I wanted to know if anyone has had success in getting ABS to work after swaping to a 1jz setup.
I have changed the abs/trac ecu to abs obly ecu
I have the abs speed sensor = dont know where i should be hooking this up to (driftmotion sells them)
I would like to figure this out before it starts to snow cause power in snow with no abs or trac =
Old Oct 30, 2009 | 06:48 PM
RyanV's Avatar
RyanV
You might call Dr Tweak, he can make anything work. Don't expect the answer for free though...
Old Oct 31, 2009 | 11:48 AM
BigGreen's Avatar
BigGreen
I have spoken with the good Dr. He is the one that has helped with my harness. He isnt sure that it has been done successfully yet
Old Oct 31, 2009 | 03:53 PM
RyanV's Avatar
RyanV
That's odd. So how do I know if I have ABS after the swap? The ABS light isn't on?
I assumed he just makes it work.
Thanks,
Ryan
Old Nov 1, 2009 | 08:31 PM
BigGreen's Avatar
BigGreen
maybe yours works. Easy way to find out is to stomp on the brakes and see if your wheels lock up.
did you have traction control on your car and what year is your car along with what engine swap?
Old Nov 2, 2009 | 11:30 AM
OneJay's Avatar
OneJay
No ABS for me but my light is on.
Old Nov 2, 2009 | 07:03 PM
RyanV's Avatar
RyanV
I have a 1995 5spd(no traction control) chassis
with an automatic(no traction control) 1992 1jzgte Soarer engine set.
The ABS light is not on.
I've never had to stomp the brakes due to the Supra calipers at all 4 corners, but I will do it and see what happens.
Old Jan 18, 2012 | 01:29 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Bump, is there a solution to this? I am at this dilemnia now...
Old Jan 18, 2012 | 02:46 PM
INTIMAZY's Avatar
INTIMAZY
92 SC300 5-speed non-trac.
Soarer 5-speed non-trac swap (year unknown).
No light and I'm almost certain my ABS works. I have stomped on the brakes in icy spots last few weeks and it appears to work as before. However, I'm not sure how many channels this ABS is nor do I know what the operating parameters are in terms of what speed it will or will not activate so I'm not terribly certain that it works fully.
Old Jan 18, 2012 | 05:21 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I found another thread that also mentioned the ABS sensor from Driftmotion. Can anyone simply explain this one?? In details
Old Jan 18, 2012 | 06:27 PM
1980's Avatar
1980
I also have the non traction control 1jz. I have abs. not sure if that is the issue but sound like something in that area to look into to get it to work. Maybe swap out the unit with your eom unit or look into the wiring. I know on my gs300 the abs and traction control work together. I had to check all the components to find the problem.
Old Jan 18, 2012 | 06:38 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Maybe you are right abou this problem. I do have both components being a SC400 with trac and ABS. I am not worried about traction control just the ABS, cause this car sucks at slowing down...
lugnutz16
RX - 4th Gen (2016-2022)
Dec 19, 2016 11:55 AM
BigGreen
Jun 19, 2014 03:50 AM
BigGreen
Jan 18, 2012 06:40 PM
RocketGuy3
Suspension and Brakes
Aug 12, 2008 09:22 PM
