2007 is250...nav unit is dead. Quick question..
Old Jul 5, 2011 | 12:51 PM
AllBizNiz's Avatar
AllBizNiz
Default 2007 is250...nav unit is dead. Quick question..
Hi. My nav unit died in my 07 is250. The ac had been working, but I decided to unplug the battery to try and get the nav working, but its still dead and now the ac cannot be turned on. Is there a way for me to turn on the ac without the nav unit? I live in Florida, so driving without ac is not an option. Also, if someone can direct me to some repair options for the nav, id appreciate it.
Old Jul 5, 2011 | 02:19 PM
slee18's Avatar
slee18
sounds like the display went bad on it. Your probably going to have to replace the entire screen. More than likely a dealer item only unless you find a used one.
The touch screen still works you just have to assume it is on it was home page of the navi screen and use the manual to guide you through. Hop that helps.
Old Jul 5, 2011 | 02:28 PM
KillaIS250's Avatar
KillaIS250
Few users have had the same issue - the display and/or touch screen dies. The common answer from the dealership is that the whole unit needs to be replaced, there's no "screen only" replacement. But others have found solutions, try searching and seeing if you can find the threads or wait and see if others post here.
Old Jul 5, 2011 | 03:22 PM
AllBizNiz's Avatar
AllBizNiz
Before the screen went completely dead, the touchscreen was no longer working. I was going to put off fixing it (ive read $2400+,) but without ac, its unbearable down here. If someone knows a way for me to turn the ac on without the front panel, it would be a life saver..Btw, the radio works, but im assuming its a separate piece.
Old Jul 5, 2011 | 03:35 PM
simple's Avatar
simple
My screen went dead yesterday while I was sitting at a light, the radio still played but no screen. Says something along the lines of "Check system", I'd pulled over and restarted the car and it went back on. Guess I'm gonna have to keep an close eye on it. If it's gonna go out, it better go out now so I can have the dealer replace it under warrenty.
Old Jul 5, 2011 | 04:28 PM
KillaIS250's Avatar
KillaIS250
If your close to the end of the warranty, report that to your dealer NOW. That way, if it does go out shortly after your warranty is over, you'll have a paper trail saying you did report the issue previously. It may be enough for corporate to fulfill your claim outside of warranty.
I've read this being done by someone else with a transmission (non-Lexus tho). The person kept reporting that there was intermittent issues, but the dealer didn't fix under warranty. Of course, warranty endded and the transmission died. But the person got it replaced anyways because issues signaling it may die happened before warranty.
Old Jul 6, 2011 | 07:09 AM
Lil4cyl's Avatar
Lil4cyl
Mine is an '09, but do you have the AUTO button below the screen? Even if I cut the a/c off through the nav screen, I can hit off, and then the auto button and the a/c will come on. Then just adjust the temp down with the up/down buttons. Not sure but maybe my a/c is defaulted to turn on when I push the auto button.
Old Jul 6, 2011 | 07:56 AM
allst4r's Avatar
allst4r
check out the voice commmands... there is a whole list.. my nav went out on me also. and got the whole thing replaced under warranty...
NAVI Commands
Command Alternate Commands with same function
Current position Current Location
Map
Cancel
Zoom In
Zoom Out
Right Map Zoom In
Right Map Zoom Out
North Up Change to north up
Heading Up Change to heading up
Map direction Change to map direction
Right map north up
Right map heading up
Right map direction
Dual map Change to dual map
Single map Change to single map
Mark this point Mark
Home Go Home
Repeat Guidance Repeat voice, Repeat
Louder
Softer
Arrow guidance Arrow guide, Change to arrow guidance, Change to arrow guide
Turn list guidance Turn list guide, Change to turn list guidance, Change to turn list guide
Entire Route map Entire route, route overview
Delete next destination Cancel next destination
Delete final destination Cancel final destination
Delete all destinations Cancel all destinations
Suspend guidance Stop guidance
Resume guidance Start guidance
Compass mode Change to compass mode
Lane guidance Change to lane guidance, Guidance screen on freeway
AUDIO Commands
Radio
AM AM Radio
FM FM Radio
FM1
FM2
CD
DVD
CD Changer
DVD Changer
Cassette
Tape
Audio Audio on, Audio off
Seek up
Seek down
Type up
Type down
Fast forward
Rewind
Reverse Program
Next track
Previous track
Skip backward
Play
Track up Next track
Track down Previous track
Disc up Next disc
Disc down Previous disc
Climate Commands
Automatic Air Conditioning Automatic Air Conditioning On, Automatic Air Conditioning Off
Raise Temperature Warmer
Lower Temperature Cooler
65 Degrees Temperature 65 Degrees
82 Degrees Temperature 82 Degrees
83 Degrees Temperature 83 Degrees
84 Degrees Temperature 84 Degrees
85 Degrees Temperature 85 Degrees
Help Commands
Help Command help, Command list
Old Jul 6, 2011 | 08:16 AM
simple's Avatar
simple
Thanks for the heads up, bought my 350 in Aug of 09 and since put 12k milage on her, hopefully nothing goes wrong but I did perchased extended warrenty just for this kind of BS. She probably has more wires than my house do, lol...
Old Jul 6, 2011 | 09:25 AM
Evitzee's Avatar
Evitzee
For owners that plan to keep the car past the warranty period this one item alone probably makes it a good idea to buy the extended warranty.
Old Jul 6, 2011 | 10:18 AM
AllBizNiz's Avatar
AllBizNiz
The auto button isnt working. Everything above the radio is dead....As for the voice commands, you got me all excited, but nothing. The radio control buttons on the left side of the steering wheel work, but the voice command button on the right does nothing.
Old Jul 23, 2024 | 02:33 PM
isitisorls's Avatar
isitisorls
2nd gear
Did you ever find a workaround? I’m in this same predicament and all I want is some A/C
Old Sep 12, 2025 | 09:18 PM
NovaSt4r's Avatar
NovaSt4r
1st Gear
Same issue here...
2008 IS250 w/ 250K miles
Last week I go to turn on the car and the NAV screen develops horizontal lines during bootup then it fades to a white screen and then dead/black. Hasn't worked since then.
All buttons above the clock won't work. I checked all fuses, all good. Took it to a local mechanic and they tested the electrical, voltage and ground is going into the unit. They advised to replace the unit.
I took the unit completely apart and couldn't find any burnt capacitors or ICs on the electrical boards.
I also tried installing a new Digitizer screen but no dice.***don't waste your time doing this unless the NAV screen is on but not responsive to the touch, this is when you replace the Digitizer***
Going to take the NAV apart again and pop the boards into the oven and see if it fixes it (sometimes this trick works as the heat reseats the solder points).
My last ditch effort is to pick up a used unit from my local junk yard
If I can't find one them I guess I'll have to buy an after market one, not a fan of those since they tend to have low quality audio and I hate those crappy microphones and GPS antenna, not to mention installing an aftermarket camera when the car already has one.
PS: my local mechanic was able to turn the A/C on for me (don't know how tho), but it shut off again when I took it out. I'll be going back to ask them to turn it back on and this time I'll watch and see how tf they did it, I'm guessing by jumping a pin from one of the connectors.
Lexus first screws us over with the carbon buildup on the piston heads, and now this... so done with this brand, they're useless.
apex47
Nov 7, 2022 08:08 AM
Ken167
Jul 22, 2016 02:04 PM
OoAaronoO
May 22, 2016 06:45 PM
drewster12
Sep 27, 2013 06:41 PM
n8doggdago
Oct 1, 2008 11:57 PM
