Upgraded to Figs when I had my IS F and ended up leaving them on the car when I got rid of it. Not sure how much these go for but if you're interested let me know. will probably just go in the trash if nobody takes them.
Do you know if the suspension will fit on a 2006 IS250 AWD?
The oem LCA bushings should fit. It's the same bushings used on many different Lexus models. FYI, these goes new around $50-$80 a pair online depends on the dealer. I also have a pair laying around but not worth much to sell them.
Thanks. The dealer says I have to replace my entire lower control arm. They said I had to replace the bushings. There are a bunch of them. Don't know which one is causing trouble. Going to take it to a mechanic soon. Just wanted to line up parts for it so everything can be done at once
