Can Someone Explain "Offset"
Can someone explain what the "offset" of a wheel is? It looks like it might be a distance, measured in millimeters. What does this value represent? Why should I care about it when I'm wheel shopping?
VIP|EXEstyle セルシオ
https://www.clublexus.com/forums/sho...explain+offset
You can also try a search on "explain offset." There should be a bunch of threads on that topic.
Boardroom Thug
Laugh, just about the same time. Here is 3 diff ones
url]https://www.clublexus.com/forums/showthread.php?s=&threadid=78889&highlight=Explain+Offset[/url]
https://www.clublexus.com/forums/sho...Explain+Offset
Former Sponsor
Offset
Offset is the distance in millemeters from the centerline of the wheel to the mounting flange. Check this out...
http://www.tirerack.com/a.jsp?a=DZ1&...ech/offset.htm
It's also worth mentioning that the 'Tech' section @ TR has several great articles on wheels
Centerbore
Finishes and Care
Offset
Performance Benefits
Proper Lug Nuts or Lug Bolts
The Plus Concept
Tire & Wheel Package Ride Quality Confirmation
Using Alloy Wheels on the Track
What Determines Quality?
What Is An Alloy Wheel?
Wheel & Tire Owner's Manual
Wheel Construction
Wheel Lug Nut Torquing
Centerbore
Finishes and Care
Offset
The Plus Concept
Wheel Construction
Duh!
You're right, I'm so used to posting in the GS forum that I forgot. I'm curious about the factory offset on a 2003 GS300.
Originally posted by GraceGSGrl
Follow-up question: What is the offset on the factory wheels? Is 0 (zero) a fair assumption?
real quick..larger numbers place the overall wheel closer towards the middle, but then there's disc fitments and wheel design that change things up as well
