View Poll Results: What is the correct tire pressure for a 98 GS4 with stock 16s?
32psi cold
27.50%
33psi cold
10.00%
34psi cold
20.00%
35psi cold
22.50%
36psi cold
20.00%
Voters: 40. You may not vote on this poll
Correct Tire Pressure?
Man, I've been getting sucky mileage lately and can't understand why. The only two things I can think of are the tire pressure which may have changed or that I put in my TEIN HA's.
Does anyone know the correct tire pressure (cold) for the GS4's with 16 stock (soon to be changed)? Everyone seems to have a different opinion.
My driving style hasn't changed, but I'm losing like 2 miles per gallon every fill up.
kevs,
I don't think lowering the car will cause your gas mileage to go down. If you want the exact tire pressure you should set your tires at, just check the sticker inside the driver side door.
Your car might just need a tune-up, or it could be after you lowered your car, you might be taking just taking the corners harder punching the pedal more making you use more gas. Dunno?
Lets be honest, you've got a heavy foot and it got a bit heavier when you added the new suspension. 34-35 psi should do. Running the pressure too high will only ware your stock tires prematurely. They are not designed to run sucha high tire pressure.
For stockies, I used to put in 35 psi all around. Too much air, and you get premature tire wear in the middle, plus a bumpy/skippy ride. Too little air, and you get premature tire wear on the outsides of the tire, plus lower gas mileage, decreased handling and decreased acceleration.
For my 19's on Falken Azenis, I use 38 psi all the way around.
