Different centerbore - smaller to larger, what bad happens?
Forum Administrator
I'm looking into the possibility of using some Lexus wheels on a Mazda (long story, it's for a "Lemons" Mazda 626 race car) and my crack research team (google) tells me that the bolt pattern is the same 5 x 114.3, but the centerbore is different.
Lexus is typically 60.1
Mazda is typically 67.1
I've always read of using centering rings but assumed those were for fitting larger bores to smaller bore wheels... but I'm no expert in this area.
Can anybody tell me if I can make these work?
you should be able to take it to a machine shop and have them enlarge it.
this guy had STI BBS rims machined to fit on an IS. the bore for the STI was like 56 so it was smaller to larger.
http://my.is/forums/f95/sti-bbs-is3-...e-pics-381487/
Just down to 67 outer diameter to 60.06 inner and you are good.
He's trying to put the Lexus wheels onto the Mazda, not the other way around.
You'll need to have a machine shop bore out the wheels. No one I know makes anything that reduces the center-bore. I guess you can make spacers in such a way that they'll work, but its probably cheaper just to bore the wheels.
^ I was thinking the same thing...Dave is trying to place these on the Mazda not the other way around. You can do one of 2 things have the center bore corrected with a machine shop if it wont take away from the rim. The other I was thinking you can get a bolt on spacer, like Ichiba Type II, with the correct center bore/adapter if they have it. Just an idea for something to look into.
Hi Dave.
You can make this work if there aren't any other offset or interference issues present. Some of the OE Lexus wheels are somewhat high offset, so keep this in mind.
Opening the hub bores is not a big deal. A good machine shop should be able to do it for you. The hardest part of this is getting a machine shop to 'fuxture' the wheels (hold them in the machine) without damaging the finish. If they're going on a race car this probably isn't a huge concern.
There are two methods for opening the hub bores: turning the wheels on a lathe or cutting the hubs on a mill. Most shops around here would prefer to just fixture them on a mill, indicate them in (to ensure they're centered) and milling them. Chucking them up on a lathe arguably is better/more precise but requires more set-up.
The biggest issue I see is the lug nuts. The Toyota/Lexus OE wheels use a shank style lug nut with an integral flat washer. Don't use a different nut, like the OE Mazda they won't seat properly. Use the OE Lexus lug nuts!!!
Hit me up if you need help! bigaudiobob@gmail.com
Wheels
Jim
