Spacer Question
Spacer Question
I just wondering where i could get a pair of 15mm spacers? Do they make the 15 mm spacer without the bolts already on it? If they do how does that work ? Does the stock hub come off in the front to put the spacer on
The reason I'm asking is because now i have the Supra breaks so if i ever want to go back to stock wheels i have the spacers.. Thanks
tony
tony
tony
tony
Wheel adapter = attached studs
If you get spacers that are thicker than a few mm, then it is recommended that you replace your stock studs with longer ones.
Wheel adapters with attached studs should be a minimum of 15-20mm thick, or else they'll be too weak to support the attached studs. The benefit of wheel adapters is that they bolt right up w/o having to worry about changing the stock studs. Also, they're often made specifically for the car and are hubcentric.
Instead of machining the H&R 25mm adapters, you can get a set custom made: www.wheeladapter.com. I'd suggest emailing Fred at this site if you have any questions - he's been custom making them for years and has 3 CNC machines in his shop, so he knows his stuff.
Romil is this what you are talking about... how does this slide onto the stock hub? also do i need hubscentric spacers? i would assume i just use my hub rings like i do with the stock hubs? This is really confusing me... Is there any pics that eplains this better?
Tony
Originally Posted by rominl
this is an adapter. you put it on the stock hub. you see the 5 holes? they go on the 4 stock studs, and you bolt it on tight. and then you put your wheel on it afterwards.
you should get hub centric ones
Tony
exclusive matchup
Sory I'm being a pita but thats what i need right? Thanks for replies henry. You definitley know your stuff
Tony
Tony
