Platinum cup kit
I know the platinum VIPs cup kit will work on the front and was told that they will work on the rear too. I've had a cup kit on the front of my 2007 LS460 for a year and a half and daily drive aired up during the spring/summer months when I have my summer wheels on (2 seasons now). I can say enough good things about them. Pm me if you have any questions
They can make the rears work both ways.. they'll either rebuild the rear coilover and convert it to a 1 piece coilover or build the cup kit off the spring bucket/lower arm spring seat.
Most of the Cup kits they build for the BMW and AUDI guys that have the separate spring and shock setup all go with the cup over the spring in the spring seats with the shocks as is.
I'm going with the 1 piece coilover conversion.
I was thinking of changing my rear into a 1 piece coilover but you would need to reinforce the top mount of the body. One of my friends had a 1piece conversion on his G37 sedan and it ripped the top portion due to the stress and wight of the car. I was also thinking about the buckets but you would need something to secure the springs and cup when the cup goes up. if you hit a bump the spring might separate from the cup. It is possible to make a rear cup but it would take a lot of modification.
Will my friend did track, drift and accrued a lot of mileage on the car which probably caused it to rip off. I can see a coupe working for a true coilover, but I cant see it for a sedan where I think weight will be the problem. Your genesis is way lighter compared to a GS for one thing. Also since its a sedan and I'm just guessing because I have friends/family seat in the back which will be added weight and stress to the rear.
Only front unless you mod the coilovers or the arms for the rear, but might cause damage in the long run
Dnights
GX - 1st Gen (2003-2009)
06-15-12 01:32 PM
Vitmn R
Suspension and Brakes
11-15-04 05:01 AM
