Lower Compression Bushings - What offset?
Hi. I have a IS 250 and one of my lower compression bushings is starting to fail. I was looking at ordering a new set, however, I noticed that they come in a -20,0 and 20 offset. I am assuming they come from the factory with a 0 but wanted to see if anyone can verify?
Also, does the IS-f use the same bushing as the IS250 or is it stiffer?
Part 48075 and 48076: http://www.lexussouthatlantaparts.co...driveLine=8058
The bushings only come with the brackets from Lexus. There is no pressing involved.
RH: 48075-24010
LH: 48076-24010
Both of these are for 0 caster adjustment, and what I'm running in my IS250.
Jeff
RH: 48075-24010
LH: 48076-24010
Jeff
Sponsor
Hi All, we recently introduced the Ultimate Steering Response System (aka "USRS") and we are getting tremendous reviews on the ISF forums, I invite everyone to check out the huge feedback we are getting.
We are not just selling bushing, its is a bushing/housing system that completely changes the LCA bushing design to a thrust loaded setup that is superior in every way to the stock setup. Improvement in steering feel, feedback, braking, and reduced tire wear is big.
We have already competed several RCF installs and the improvement is huge. The more grip you have, and the more aggressively you drive, the bigger the gains.
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Sponsor
here are some reviews from the ISF forum:
https://www.clublexus.com/forums/is-...rr-racing.html
__________________
Sponsor
Hi... please read the reviews of our USRS... we have sold a ton of these, and to the best of my knowledge there are no complaints regarding stiffness.
Rafi
__________________
