Should I buy a used rack and pinion?
Old 04-24-14, 09:39 AM
islexusred
islexusred's Avatar
Default Should I buy a used rack and pinion?
My 98 Gs400 right boot on the rack and pinion started to leak a few days ago! Replacing the boot alone is not an option. Would you recommend it to buy a used rack and pinion ( not refurbished) but coming off of a salvaged car.
PS: the seller seem legit.
Old 07-27-15, 10:17 AM
jbar2016
jbar2016's Avatar
I have been looking for a steering line at the local yards, most steering systems seem bad, leaking, and torn up. I would buy a new rack, for the warranty as i wouldnt trust a car i cannot see, if you do decide to buy used, make sure the system is not open. after a car sits and the system is leaking fluid, the fluid will settle and moisture will get in and kill tge pump and rack
Old 07-27-15, 02:50 PM
GSteg
GSteg's Avatar
Even if the used rack is not leaking, you don't know the condition of the inner tie-rods. For the work that's required, it's not worth the saving if the rack leaks again or the rods become loose. I bought my re-manufactured rack for $275 and that includes everything. So far no problem, but at least it came with a warranty.
Old 08-01-15, 01:05 PM
marshun
marshun's Avatar
^that
get a reman so theres nothing else to worry about. i did as well when mine leaked
kenaston99
08-23-18 10:12 AM
Sactolex
Performance & Maintenance
22
03-07-16 03:47 AM
Farino81
06-08-09 11:14 AM
ICONYQ
Suspension and Brakes
02-03-09 01:01 PM
Brownmagic
Maintenance
01-20-08 07:12 AM
Quick Reply: Should I buy a used rack and pinion?
