AWD Lowering Issues
Old 01-01-14, 09:57 AM
1BadTitan
1BadTitan's Avatar
Default AWD Lowering Issues
I've been going back and fourth for months about whether or not to lower my car. I want wheels, but think they will look bad at stock height... Especially AWD height. This vibration issue people have with lowering AWDs is the only thing keeping me from pulling the trigger. Is there any fix for this? Is there a way to lower it a little bit without issue or what? Many ppl say its getting intolerable, but if u google search is250 awd lowered, theres a million results. All these ppl cant have this issue and just deal with it. These cars are too clean and perfect looking to be dealing with a ****ty vibration problem.
Old 01-01-14, 10:25 AM
Scless
Scless's Avatar
I read somewhere that a member on CL was making some axle spacers of some sort to help with the vibrations. Not sure if he's still around... Vibration is bad but you'll get use to it. The general height AWD IS stays at is 24.5-25 inches fender to ground. Good luck
Old 01-06-14, 07:04 AM
1BadTitan
1BadTitan's Avatar
I dug around and saw something about axle spacers, but nothing solid that was anything more than a pipe dream. I was hoping someone had a fix
Old 01-06-14, 07:29 AM
Stainless9
Stainless9's Avatar
I tried the axle spacers and currently still have them installed. Vibration is still there. Not sure if it actually decreased the amount of vibration, but...its still there. Could be the placebo effect lol. At the end of the day, I got over the vibration. At first it bothered the heck out of me but stock height IS AWD has slight vibrations as well. You'll get over it unless you want trade the car in for something else. Stock height AWD looks unapealling in my opinion so for now, I am putting up with the vibration.
Old 01-08-14, 11:09 AM
ChrisKlug
ChrisKlug's Avatar
I lowered my IS250 AWD and it shakes a little in the seat when going from a stop to 20mph. I honestly don't realize anymore I got use to it already.
Attached Thumbnails AWD Lowering Issues-560079_10153572547295004_545032369_n.jpg   AWD Lowering Issues-1463071_10153572552260004_1556641019_n.jpg
Old 01-08-14, 03:44 PM
Censee
Censee's Avatar
im trying to find a solution with a driveshaft shop.... heres the thread https://www.clublexus.com/forums/sus...ml#post8314203
Old 01-10-14, 01:09 PM
sm1ke
sm1ke's Avatar
There's 2 kinds of "vibration" that people seem to be experiencing.
#1 is the vibration some get while at a complete stop. It's very mild, but it is noticeable to the driver.
#2 is the "wobble" some get during acceleration, kind of like if you have a bad balljoint on one side.
I've experienced both. The vibration at a complete stop is so minor that I barely notice it anymore, and to me its worth it compared to the high ride height of the AWD. The wobble does worry me, but I'm hoping that I can correct it with a proper camber kit install and alignment to get everything back to spec (in terms of toe, camber, and caster, at least).
EDIT: I'm on BC coils and 19s with 235/35 fronts and 275/30 rears. Lowered all around to about 25.25" fender to floor.
Old 01-17-14, 02:36 PM
Censee
Censee's Avatar
i dont know much about suspension, but i heard some people with other cars have this wobble/vibration problem after lowering and they get adjustable upper control arms and it seem to help...anyone try this?
Old 01-18-14, 05:14 PM
JBLover
JBLover's Avatar
Does the wobble cause any damage? I thought I read it tears up cv boots or something.
Old 02-07-14, 11:41 AM
Carbonsrt
Carbonsrt's Avatar
We have a AWD lowered on Megan springs for over a year with no vibration. Only thing we have run into is the place we had align it didnt do a good job and we wore down the passenger side tires worse than the rest.
Old 02-11-14, 04:29 PM
1BadTitan
1BadTitan's Avatar
How much drop did the Megan springs give you?
Old 02-11-14, 05:44 PM
reyoasian
reyoasian's Avatar
^ the orange ones? roughly 1.25 all around
Old 02-11-14, 06:56 PM
Kappy550
Kappy550's Avatar
My 07 AWD is lowered on H&R springs. Im replacing the front CV axles on Thursday. I will be living the vibration free lifestyle after that. For a while...
Old 02-12-14, 09:21 PM
DaveLexus
DaveLexus's Avatar
i want to get road magnet springs for the 2 inch drop i hope i wont get the wobbles or shakes!
Old 02-13-14, 05:57 AM
Sfrt
Sfrt's Avatar
Just lowered mine on BCs a couple weeks ago and have both the types of vibrations described by sm1ke above.
I wouldn't want to warn you away from doing this because I agree that the look may be worth it.
However ... Be forewarned, there is no camber adjustment and if you want to get everything right, budget more for front and rear camber adjustment parts and labour - and ideally, get this done when your coils go in and before your alignment.
On a related note (and I'm about to create a thread for this) if anyone has experience DIY with removing the front upper ball joints and/or installing the SPC ball joints, I'd really appreciate info/advice on the process.
Quick Reply: AWD Lowering Issues
