who here tracks their SC? brakes?
Hey Everyone,
i just picked up a 92 sc400 with a clean black body and from searching around the most common brake upgrade is either ls400 or supra tt calipers (at least on the front)
i used to have a 240sx with a built motor etc etc, i will post an official introduction in the proper place later.
My question is, as this is my more comfortable commuter car and also going to be a weekend warrior, who here tracks their sc300/400 and what brakes do you run? I don't mean autocross, i mean 20 minute or more circuit / grip sessions, as thats what i want to do with this after i swap a 1jz in it.
cheers
Marko
edit: probably should have posted in the brakes section that i just noticed..lol.
cheers
Marko
Pad selection is limited with the ls400 front calipers. But the price is right when compared to supraTT calipers. I think it would come down to your budget, but obviously the supraTT would be the way to go so you could have more pad options.
from looking at autozone/oreilly, supra calipers and LS400 calipers are the same price, so i don't see a huge price difference there. I guess i was hoping to see if others here have successfully done track sessions on their sc300 with LS400 aluminum calipers and some pads and not warped the calipers (in 300zx they switched from Aluminum to Iron for brake calipers in the early 90s for that reason). Or with any calipers and just have some input about this car on a track.
Marko
Marko
http://www.autozone.com/autozone/par...152042_0_5913_
does this look like the right part to you guys?
i think (this is what i've done before) is that i can order these calipers, pay the core fee, and then take my old sc400 calipers in and get the core fee refunded. i will probably go this route, as i don't want to spend 1000+ on some wilwood or stoptech goodies.
where do you guys get stainless lines for supra brakes? are the lines the same as sc400 stock brake lines?
cheers,
Marko
cheers,
Marko
No experience to tell yet, but I am also planning on tracking my SC this year. I currently have stock TT fronts and stock SC rears. I will probably go wtih TT rears in the near future.
Even with Supra TT brakes, you're going to experience brake fade with the SC on the circuit. If you are NA you could probably get away with Supra TT brakes and some aggressive pads. I wouldn't even consider LS brakes an option for what you are trying to do since there isn't many pad options for those calipers. For people who are just trying to get a 4 pot brake system on a street car, it's a great option. But I wouldn't say the same if you are planning on tracking your car.
If you get the TT supra calipers I recommend carbotech pads.
http://www.ctbrakes.com/brake-compounds.asp
cheers,
Marko
cheers,
Marko
I still plan to ditch the LS400 fronts and get a set of supra tt front and rear calipers for my car though.
However, the Supra calipers are worth their weight in gold for a reason. The pad selection on top of that made it a no brainer for me, I have them on the front and rear of my car right now. I wouldn't hesitate to autocross it (once I have new bushings in, I'm slightly OCD like that), however I would NOT track this car even on the Supra rotors for more than a lap or two at a time. If you go the same route as me, I advise investing in some slotted rotors and metallic-compound brake pads. Don't forget to switch to a higher rated brake fluid as well.
Also, just because the Supra name is on the caliper doesn't mean it has to be expensive, OP. Check around on the classifieds here, you'd be surprised at the deals you find.
Track pads not only handle high heat better than OEM style pads, they flat out REQUIRE more heat to work. The first stop on a cold race pad can be downright scary (and very unfriendly to rotors!)
Supra TT brakes, front brake ducts, FRESH fluid of your liking (don't get too caught up in temperature ratings) plus a good race pad and you should be fine for a 20 minute heat.
I would skip on the drill/slotted since high heats pads + drilling is generally not a good combo on the budget most people here operate on.
