brake booster question
Old 12-12-11, 04:20 PM
rylee
rylee's Avatar
Default brake booster question
whats the difference between a 99-00 and 01-05 brake booster
any input will be greatly appreciated.... THANKS
Old 12-14-11, 10:23 PM
sam430
sam430's Avatar
one sensor.
Old 12-14-11, 10:26 PM
sam430
sam430's Avatar
remove all plugs... some are pointed in the arrows below. Save the washers and remember how to put the washers back on.
remove sensor with deep socket. Keep this sensor.... (this is the only difference between pre 2001 and 2001+)
go to the driver side and unbolt the brake attachment (1 bolt) and the bolts holding the booster to the body (4 bolts). Go to the engine bay and wiggle out the assembly.
Now, install the new assembly. Tighten the 4 bolts and the brake thingamajig lever..the thing you step on to stop
go back to the engine bay and remove the sensor. Now replace it with your pre 2001 sensor and plug everyting back in.
Old 12-15-11, 02:02 PM
rylee
rylee's Avatar
thanks sam430 reall appreciate it...should i use my original sensor off my brake booster? as my brake booster is no good would the sensor be good still?
Old 12-15-11, 02:57 PM
sam430
sam430's Avatar
Yes. The sensor hardly go bad. Take it off while the whole unit is still in the engine bay....very hard to remove sensor after you pull the unit.
Remove sensor. Keep it.
Remove the whole assembly.
Replace with the replacement.
Remove the sensor of the replacement after mounted....then put the original in.
Old 12-15-11, 05:33 PM
rylee
rylee's Avatar
do u know the name of the sensor? thanks bro u been a big help...
Old 12-17-11, 02:16 PM
tx1979
tx1979's Avatar
Thumbs up
Thanks for all the info Sam! Just one more question:
Does this replacement throw up any strange codes / idiot lights with the braking system?
Just curious and about to start looking for a 2001+ part.
Thanks again!
C.
Old 12-19-11, 04:33 PM
sam430
sam430's Avatar
Thanks again!
C.
No code thrown, I was told that the braking was firmer (mine is already the newer version, I changed it on someone else's older model).
Sorry, another member would have to help...call the dealer or point it out. The can provide it right away.
Old 12-23-11, 11:32 PM
rylee
rylee's Avatar
Thanks sam for all ur help....
Old 12-23-11, 11:35 PM
rylee
rylee's Avatar
Does anyone know how to turn off the abs,vsc,vsc off lights.
Jus got thru changing my brake booster and dont know how to turn off da lights...any advice would be greatly appreciated.... Thanks ....
Old 12-24-11, 02:55 PM
bonestock5
bonestock5's Avatar
Do our cars have an ECU fuse? On my Honda I reset the ECU by pulling that fuse.
Old 01-09-12, 11:31 PM
tx1979
tx1979's Avatar
Red face
Not sure if the size was mentioned elsewhere, but to remove and replace the sensors out of the old and new units you need a 30mm socket.
The original MCU sensor that needs to be transferred is shorter and can be removed fairly easily - as long as you have a decent sized breaker-bar. The sensor on the 2001+ MCU is a bit longer and requires a very deep socket. Make sure you've got a 30mm Deep Socket before you start this project. As mentioned before it really helps to remove and replace the sensors while the MCU is mounted in the car.
Did this yesterday with a lot of help and couldn't be happier. Night and day difference and no more screeching! Thanks CL members for the invaluable info. once again.
Old 02-20-12, 07:34 AM
justablkv8
justablkv8's Avatar
sweet, thanks for this - needed it!
Old 03-09-13, 11:15 AM
KAJmapper
KAJmapper's Avatar
if any of you do end up replacing your master cylinder/brake booster components can I buy the old broken ones from you ?
Please pm me
LexusFlex6
08-11-18 03:54 PM
WolfManRCF
RC F (2015-present)
11-30-17 09:02 AM
ez12a
10-21-17 10:42 PM
osetleo
RX - 1st Gen (1999-2003)
07-11-17 04:52 PM
mrchacon
06-28-09 10:39 PM
Quick Reply: brake booster question
