Bilstein Sport Shocks
I just ordered a set of Bilstein Sport shocks for my GS400. I have searched this forum and see that most people who used them have lowering springs. I know bilstein designed them to work with lowering springs, I however plan to use my OEM springs because I am looking for the stiffer ride without losing ground clearance. Will there be any adverse effect by using the OEM springs on these shocks? Thank you in advance.
-Jay
-Jay
The rule of thumb I've always used was:
Mild lowering (0.7-1.2) matched with KYB shocks
Moderate lowering (1.0-1.5) matched with Bilstein HD
Aggressive lowering (1.5-2.0) matched with Bilstein SP
tiguy99 (02-22-17)
Bistein makes two shocks for our cars, you are correct. I'm not sure of your goals but if you're going with mild lowering (0.7-1.2 Eibach) the HD might be a better choice. Bilstein SP shocks are better paired with moderate/aggressive lowering (1.0-1.9 inches) and have stronger dampening
I just raised my car back up on OEM springs with Bilstein Sports. Ride is so much better now. Hopefully I won't be going through tires as often now that the camber is back to normal. Highway float is slightly more noticeable, but you don't feel every pebble on the road like before.
how about this setup? bilstien sports + k sports springs 99 gs300.
how much of a drops you guy think it is? and how the comfort of it?
i'm taking the cheap route at the moment because its a daily for my
dad. I'm planning to put go air probably in a year or so when it get pass
onto my little brother.
1bimmer
Suspension and Brakes
31
10-01-16 02:14 PM
