ABS and VSC light on after upgrade, help!
Old 07-14-02, 02:09 AM
thwang99
thwang99's Avatar
Default ABS and VSC light on after upgrade, help!
I just had 1 inch lowering springs (Eibach Pro-kit) and new shocks installed in my 2000 Lexus GS400, with navigation system.
Now the ABS lights and VSC lights stay on! The store couldn't figure it out. They tried disabling the batteries for a while to reset the computer, but that didn't work. Does anyone know why this would happen? Is it due to the navigation system?
Any clues on how to fix this? Their advice was to drive around and maybe it would go away after a while. They were closing, so I just said thanks and I drove away. Thanks!
- Tony
Old 07-14-02, 03:14 AM
bravo261
bravo261's Avatar
this is a weird problem. can't say i have an answer, but don't see how the nav could be an issue. had a shop install my similar hardware with nav and all went well. must've been the same for most others. is your shop a pretty good one?
Old 07-14-02, 08:01 AM
Mr GS400
Mr GS400's Avatar
If I recall there are sensors for both ABS and VSC either on the brake calipers or connected/routed via suspension parts. So possibly during the install of shocks/coils the interface (eg. connectors, wiring, etc) to these features might have been (either) disconnected or loosened. Worth a look if the problem doesn't 'fix' itself.
Good Luck!
Old 07-14-02, 10:15 AM
Received 2,127 Likes on 1,379 Posts
They may have damaged the cables to one or both speed sensors. They're right behind the shocks/springs by the sway bar. My TRD front sway bar was originally installed incorrectly and I ended up destroying 4 speed sensors :eek:. It was eventually fixed though.
Hope you get it fixed.
Old 07-15-02, 06:05 AM
mumbles
mumbles's Avatar
I have to agree with what MrGS400 and bit said. The body shop damaged one of my sensors when the re-installed a wheel, and it gave those same symptoms.
Old 08-12-02, 07:15 PM
thwang99
thwang99's Avatar
Default Problem solved!
So, the problem has been solved!
The shop couldn't figure it out, so I took it to the Lexus dealer, paid $85 for them to look at it. One of the sensors wasn't plugged in fully, so they just plugged it in. Problem went away!
Went back to the shop that did the original install, and they wrote me a check for $85. Guess the installer didn't really know what he was doing, he even looked at it the second time and couldn't figure out what was wrong.
Woohoo!
- Tony
Old 08-12-02, 07:52 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: Problem solved!
Woohoo!
- Tony
damn, how careless.... where's the shop? LA?
Old 08-12-02, 07:54 PM
RacingAristo
Guest
Posts: n/a
Wow.... They call themselves professional? <snort>
Old 08-12-02, 08:02 PM
rominl
exclusive matchup
rominl's Avatar
we should all start our own shop.....
and funny enough, springs install should be around 100 bucks at most...... so they effectively got 15 bucks out of you for the install.....
Old 08-12-02, 08:06 PM
RacingAristo
Guest
Posts: n/a
true but think about the hassle of taking your car to the dealership and the time you spent waiting for them..... what's the name of that shop?
Old 08-12-02, 08:41 PM
thwang99
thwang99's Avatar
Default Bad install of shocks
I don't want to slander the shop, I believe it was just that one worker who worked on my car that didn't know what he was doing! The person I talked to seemed competent and willing to help me resolve the situation.
- Tony
GS300freak
12-15-17 01:55 PM
Jayd41
05-21-14 09:26 PM
smokincigs
04-10-11 12:47 PM
panamabob
11-07-10 05:31 PM
carmcanc
Suspension and Brakes
09-28-06 09:17 AM
Quick Reply: ABS and VSC light on after upgrade, help!
