Uca
Old 06-27-10, 01:48 AM
sam430
sam430's Avatar
Default Uca
Guys,
We've encountered some issues with the UCA being over extended and hitting the upper wall and the ball joints being bent to it's extreme. What will it cost to make something like this?
Post other options here. Thanks.
Old 06-27-10, 02:38 AM
vwynn
vwynn's Avatar
expensive... lol
Old 06-27-10, 02:42 AM
ElitistK
ElitistK's Avatar
UCA is the lesser concern. What we really need is a shorter steering knuckle to go along with the RCA (ss kits) blocks to help reduce the uca angle and provide extra clearance, as well as further adjusting for a more balanced roll center.
However I do not know if additional adjustments are required on the uca to accommodate for such a drastic change. It's probably a good idea anyway and we do have good solutions offered on the market at this point; making your own arms would cost a lot more than buying Ikeya.
Old 06-27-10, 08:18 AM
sam430
sam430's Avatar
They ikeya looks like it would have the same problem as all the other UCA. The way my car is sitting right not, it's barely dropped, the UCA balljoint is nearly bent to the max. I'm affraid it'll just pop off after hitting a few bumps.
This is way expensive... I would make more sense to buy an spc one and bend it.
Old 06-27-10, 11:54 AM
motolex722
motolex722's Avatar
+1 for shorter steering knuckles. It would be the best option for our upper ball joint problem.
Old 06-27-10, 07:44 PM
cjames235
cjames235's Avatar
i have actually been wondering about this for a while........ why couldnt we just cut an inch or so out of the knuckle and weld it back up? it would solve all of our suspension problems (even camber)
Old 06-27-10, 08:39 PM
GSteg
GSteg's Avatar
I wouldn't want to be the guinea pig to try that out, especially since you can only weld on the outside surface. On hard turns, there are immense amount of forces that the knuckle experiences.
Old 06-28-10, 10:18 AM
cjames235
cjames235's Avatar
not totally true.... as long as its bevelled good and you are welding with enough heat, it will fill it all the way to the center.......... BUT, it still is quite alot of faith to put into a weld
Old 06-28-10, 10:21 AM
GSteg
GSteg's Avatar
That's is what I meant. You are applying weld but it's not guaranteed that it will be uniform and fill in perfectly. Essentially, stress concentration is still on the welds, which is why I haven't done it yet. Too much risk involved for an unknown outcome. Perhaps FIGS can come up with something for us.
Old 07-02-10, 08:57 PM
tom steele
tom steele's Avatar
thats what i was thinking i was going to try and design a new steering knuckle i also think this is the best solution.
Old 07-03-10, 06:11 PM
chrispy
chrispy's Avatar
A shorter knuckle could possibly solve UAS bag rubbing problems as well.
Old 07-04-10, 08:40 PM
cjames235
cjames235's Avatar
how about just converting over to a macpherson setup? that would solve all of our problems.......
Sonic_RC
Suspension and Brakes
53
08-29-17 02:46 PM
O1GS43O
06-01-10 08:34 PM
LeXaNoMicS
16
02-19-09 07:39 AM
GS1day
01-29-05 02:58 PM
Quick Reply: Uca
