Help W/ Rotors
Old 05-12-08, 05:04 PM
Vic184
Vic184's Avatar
Default Help W/ Rotors
Hey guys i have recently been feeling alot of vibration and shaking when im stepping on my brakes at highway speed. my brother and my mechanic checked it out and told me i need new rotors. now i want to get those cross drilled rotors like i had in my old car. i came across these iRotors online and i wanted to know if they were any good, heres the link:
http://www.irotors.com/storefrontpro...20&i=232925561
should i just buy those or go with the plain Brembo ones? or do you guys have any suggestions of which ones i should go with? my budget is low so i can not spend much. the help would be greatly appreciated guys thanks.
BTW i have a 99 GS4
Old 05-13-08, 11:35 AM
Vic184
Vic184's Avatar
bump!!!!!!!!
Old 05-13-08, 12:17 PM
slickgt1
slickgt1's Avatar
dude, just go with the brembo blanks. They will be cheaper and perform the same if not better. Just get nice pads, Axis Ultimates <- my recomendation. ONly problem with the Utimates is that they wear quite fast. I drive hard, and get about 10k out of them. Not bad, but I like how they brake like crazy on regular brembo blanks. Plus you can always cut the blanks, it will be way harder if not impossible to cut the drilled or slotted ones.
Old 05-13-08, 12:37 PM
GSteg
GSteg's Avatar
Not to mention, cross-drilled/slotted rotors look funny on OEM 11.65" rotors. I would only do cross drilled/slotted if the rotors filled up the wheel area some more.
tucker21
06-04-16 08:10 AM
ChanIS250
10-02-13 06:10 PM
KoSC300
NELOC
07-21-10 07:13 AM
uaaction
04-30-10 04:57 PM
nanotech
Suspension and Brakes
06-13-06 12:56 PM
Quick Reply: Help W/ Rotors
