my TRD sway bars installation + experience (many pics)
Old 11-18-12, 01:40 PM
  #61
sam12345
sam12345's Avatar
I agree, I guess Lexus did not want to compromise on their smooth ride at the time. I guess from what I read on the new cars they are learning their lesson. I also think they should do more to reduce weight. Aluminum hood, aluminum suspension parts ect. I mean my miata has an aluminum hood and it's a cheap car
I think I might try it on the track on dec 8th just to see how it does my bet is that even with the higher top speed due to better acceleration the miata will have better lap times. (arroyo seco)
Old 02-07-13, 08:21 PM
  #62
paul1012
paul1012's Avatar
nice...this should be same for my intrax sways ..right ?
Old 01-29-14, 05:47 AM
  #63
GsLex02
GsLex02's Avatar
I'd love to use this DIY but like a lot of the older posts....NO MORE PICTURES! Is there any way one of the mods can get this DIY back up and going??
Old 03-28-14, 07:51 PM
  #64
istundra
istundra's Avatar
Originally Posted by GlobeCLK
glad that the pics helped Mike!
When I installed them, I made one mistake: didn't have any grease to put on. The set didn't come with any. I figured that I'll just do it later when it squeaks.
Well after about 3 months of driving, the rear bars started to squeak.
I jacked up my car last month, loosened the bushings and added grease around the bushing. the squeaking was gone for a while, but now it's back again. I will take them off completely next time to apply grease.
so, don't forget to add grease. You will regret it if you don't.
Regretting now 5 years later! :P
My front pass squeak like my car broke!
Old 03-13-16, 08:44 PM
  #65
clintdaddy
clintdaddy's Avatar
Any chance we could get the pictures back up? =)
Old 03-15-16, 09:44 AM
  #66
sakataj
sakataj's Avatar
doubtful, OP hasnt signed in since Nov of 2015. a lot of us including myself have installed these, maybe i can help?
Old 05-05-16, 07:49 PM
  #67
firelizard
firelizard's Avatar
People who've used Prothane or other bushings instead of the factory stiff rubber that comes with TRD kits: any issues with the rear sway? I noticed the shape is different from the usual D shaped bushing. Bolt holes still line up with a universal bushing and bracket?
Old 05-11-16, 09:36 AM
  #68
shftup
shftup's Avatar
Hi, what did you order, I need some info:
Also look here for the replacement of TRD sway bar bushings - but the part I ordered for the front did not fit correctly - the rear was bang on and is very smooth;
Here is what I ordered from www.aftermarketsuspensionparts.com
191219
Product ID: 191219
Product Name: Greaseable Sway Bushings - 31mm (1.22 inch) - 90 Degree Grease Fitting
Quantity: 1
Unit Price: $18.57
> Color : Black
191154
Product ID: 191154
Product Name: Greaseable Sway Bar Bushings - 19.04mm (0.75 Inch) - A
Quantity: 1
Unit Price: $14.37
> Color : Black
https://www.clublexus.com/forums/sus...bar-f-r-2.html
Thanks
Old 05-11-16, 05:45 PM
  #69
firelizard
firelizard's Avatar
What was wrong with the front?
Old 06-09-16, 11:38 AM
  #70
firelizard
firelizard's Avatar
So, I installed my TRD Sportivo bars this week. I had nothing to worry about bushing-wise because the stock brackets and TRD bushings were compatible. The Sportivo setup feels great with DF210s on stock struts. A lot more confidence, very little harshness. Feels just like an OEM sport option should.
Old 07-31-16, 04:58 PM
  #71
clintdaddy
clintdaddy's Avatar
The pictures are not showing!
Old 08-01-16, 10:28 AM
  #72
sakataj
sakataj's Avatar
yes, you mentioned that several months ago
Old 08-11-16, 10:55 AM
  #73
99 GS3
99 GS3's Avatar
191219
Product ID: 191219
Quantity: 1
Unit Price: $18.57
> Color : Black
191154
Product ID: 191154
Quantity: 1
Unit Price: $14.37
> Color : Black
Thanks
Just for the record I can confirm the MOOG K80081 is the proper aftermarket bushing to use for TRD Front sway bar.. Rear I'm not sure as I'm running the adjustable Cusco bar back there.
Old 08-12-16, 06:34 PM
  #74
shftup
shftup's Avatar
99 GS3 - thank you very much - really appreciate your post. Just ordered them.
S
GlobeCLK
Suspension and Brakes
16
07-26-07 09:39 PM
UTGS400
12-23-05 09:09 AM
Risk3233
04-05-01 11:14 AM
Y2K1GS4
03-04-01 05:50 PM
Quick Reply: my TRD sway bars installation + experience (many pics)
