DIY Brake Flush??
Old 07-08-07, 12:38 AM
cmc07e
cmc07e's Avatar
Default DIY Brake Flush??
I have searched the forums but cant find a DIY flush. I see bleeding only. I can get a compressor automatic bleeder gun , where it has a tube that connects to the valve and a reservoir for the bleeded fluid.. Does anyone know how to do this? How much fluid do I need? Do I need to pump and hold with the bleeder gun? Any links that you guys know of for this? I read that the gs can be tricky with the ABS system, should I even try to do it my self?
My brake fluid reservoir looks pretty clean, should I even bother? I have 62K and I bought it @56K. I dont know if it has ever been done?
Old 07-08-07, 01:22 AM
GSteg
GSteg's Avatar
Keep on bleeding the brakes until new fluid comes out.
Old 07-08-07, 05:55 AM
lexusscturbo
lexusscturbo's Avatar
What about when you use synthetic DOT4 fluid(the blue stuff) you can't mix the two(old+ new)....
Old 07-08-07, 07:18 AM
GSteg
GSteg's Avatar
The ATE superblue fluid?
I have that on my car and all I did was kept on bleeding until I saw blue fluid coming out. It's that simple.
Old 07-08-07, 07:45 AM
lexusscturbo
oooh I was under the impression you can't mix the two up?
Old 07-08-07, 09:05 AM
GSteg
GSteg's Avatar
as long as it's compatible.
Old 07-08-07, 09:11 AM
cmc07e
cmc07e's Avatar
So just keep bleeding until new fluid comes out, but my current fluid already looks pretty clear, so should I even bother? And if I do how many times should I bleed each caliper to make sure its flushed, since the fluid will probably not look any different?
Also is DOT 3, DOT 3? Meaning The guy at autozone gave me the Autozone brand DOT #. IS this okay? And my original question is how much do I need?
Old 07-08-07, 09:19 AM
chuckb
chuckb's Avatar
http://www.lexls.com/tutorials/brake/bleeding.html
Old 07-08-07, 09:25 AM
GSteg
GSteg's Avatar
I bled each caliper at least 7 times just to make sure I got the new fluid in (in my dad's car).
In my car, the fluid I bought was blue so I could easily tell if new fluid was coming out.
Old 07-08-07, 09:39 AM
cmc07e
cmc07e's Avatar
Thank that link is great but is DOT 3, DOT 3? Meaning The guy at autozone gave me the Autozone brand DOT3. IS this okay? And my original question is how much do I need?
Old 07-08-07, 09:42 AM
chuckb
chuckb's Avatar
DOT 3 should all be about the same, but I'm using the ate super blue when I do mine. I'm hoping 2 liters is enough, but not sure. maybe someone who knows for sure can chime in on quantity.
Old 07-08-07, 06:30 PM
GSteg
GSteg's Avatar
I was able to do my whole car with just a bit under 1L.
Old 07-08-07, 08:07 PM
JeffTsai
JeffTsai's Avatar
If you want to do a thorough bleed, you will need a toyota service tool or equivalent that can open up the ABS unit. I paid like $350 for mine. Autoenginuity scantool with Toyota factory service/scantool option package. The old/new fluid will mix if you ever activate your ABS if you don't bleed out the fluid left in the ABS unit.
Old 01-02-08, 08:52 PM
Nosexnolex
Nosexnolex's Avatar
Is it possible to use the fuse to activet it?
abs
05-03-19 09:15 PM
peasodos
04-03-17 09:15 PM
calticboy
RX - 1st Gen (1999-2003)
16
08-23-14 08:04 PM
lexus-is2
06-05-14 11:13 AM
Quick Reply: DIY Brake Flush??
