Any advise on TEIN CS install?
Old 03-03-05, 01:12 PM
Kaine
Kaine's Avatar
Default Any advise on TEIN CS install?
Hi Guys,
After lurking in the shadows of this fine forum, I've come out of the closet
I've been reading all the suspension reviews and have decided to pick up the TEIN CS W/ EDFC. I'll be picking up the system at TM engineering in a few hours.
I was hoping on getting some feedback from any of you guys who have done the install yourselves. Any problems? setbacks? Don't do's? must do's?
Thanks Guys.
1999 GS300
18" RX300 (05) chrome wheels
Old 03-03-05, 08:06 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
just be very very vervy very careful on the abs sensor, if you damage it, it's big money
oh and welcome to cl!
Old 08-03-05, 08:37 AM
IS0LD0UT
IS0LD0UT's Avatar
Does anyone who recently installed their CS have any install instructions.?
I am fairly mechanically inclined, and have the GS Repair Manuals, so I thought I might try this my self.
Also a list of tools to have would help as well.
Old 08-03-05, 09:32 AM
joshoowa
joshoowa's Avatar
where is the abs sensor? im i worried about yanking the wiring or physically damaging it? im suppose to be installing them tomorrow so yeah i want to be extra careful
Old 08-03-05, 01:12 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
i believe you can print the installation from tein.com?
Old 08-03-05, 02:06 PM
GS300Rich
GS300Rich's Avatar
yes their website has instructions that you can print out. There are a lot of pages so you may not want to print in color or high quality
Old 08-03-05, 06:46 PM
CinFulxgs
CinFulxgs's Avatar
Mine broke when I did my L-Tuned install. They are in the front... if i remember correctly we determined that we could have done the job without removing them. Use a hanger to hold the weight of the brakes and caliper and leave the sensors in making sure they are not being stressed.
If you have to remove the sensors, don't let them hang and wrap them with a ziplock and a rubber band to make sure no debris gets anywhere near the sensor.
New ones costed I believe 360.00 from Carson which was cheap in comparison to the local Lexus dealer.
Old 08-03-05, 06:47 PM
joshoowa
joshoowa's Avatar
yeah i've been surfing tein website but i didnt see any pdf for installations. tristhan (blue98gs3) is helping me install them, hes done it twice from what i know so i should be in good hands.
Old 08-04-05, 08:02 AM
corkycal
corkycal's Avatar
the abs sensor is bolted onto the car's frame with a 10mm nut. when you take take off the brake line support from the shock, you will need to take off the other 10mm nut that supports the abs line so this line is not streched. it's important to support the whole brake and not let it dangle on the brake line. i used a wire hanger or rope to support the brakes. i believe the abs sensor gets messed up when the brake line pulls the abs senson when it's not supported.
bottom line, don't put stress on the brake lines and you'll be fine.
Old 08-04-05, 06:37 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
The install took 2 1/2 hours at the shop i went to today.... I'll post a right up later about the ride and pics tomorrow.... awesome coilovers just awesome....
Tony
07IS350
Suspension and Brakes
07-11-07 07:12 PM
TPA_STEVE
Southeast
09-08-05 07:14 PM
Lex2Go
19
01-19-04 10:02 PM
Quick Reply: Any advise on TEIN CS install?
