View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 12-04-07, 08:23 PM
  #106
Nosexnolex
Nosexnolex's Avatar
when doing this swap, supra brakes or ls400, do you guy change MBC (master brake cylinder)? what about the brake balance front to rear? do u also install brake balancer?
p.s. supra tt brakes were made by sumitomo. its a company that makes brakes for race cars and race bikes. this is why the only car to beat the supra from 70-0 is a carrera gtJ guess whom work on it's brakes? supra brakes are way ahead of the ls400 no question about it.
Old 12-04-07, 08:39 PM
  #107
FinLIFE
FinLIFE's Avatar
^ I dont know about that one, were the ls400 brakes ever tested? They are also 4 piston and lighter...Im going with those because of those two reasons and that they also look nicer than the supra ones.
  #108
GSteg
GSteg's Avatar
No one changes the MC because we have no other options other than OEM. Our ABS unit and MC is integrated as one piece, and the OEM setup is $1800.
Old 12-04-07, 08:41 PM
  #109
GSteg
GSteg's Avatar
There are a good amount of GS and SC guys who have done the swap with success. The LS400 weighs about 200lbs more than our cars so if anything, the LS400 setup is an improvement over the OEM setup in terms of brake response. The Supra's maint advantage is the larger rotors (12.7" vs 12.4"). The difference between the LS400 and the Supra is not David vs. Goliath.
Old 12-05-07, 05:09 AM
  #110
Nosexnolex
Nosexnolex's Avatar
All I can tell you is that I have done some repeated stops from 180 MPH+ in my supra and didn’t experience fade at all. I did get the discs to glow nice and red I did upgrade the pad the rotor and switched to a better brake fluid.
I had an LS430 but never did try to stop the car from such speeds, so I cant say anything about the LS brakes.
Old 12-05-07, 08:46 AM
  #111
aliga
Former Sponsor
aliga's Avatar
so why did you say the supras are way ahead of the ls brakes?
Old 12-05-07, 09:04 AM
  #112
BKzSC400
BKzSC400's Avatar
LS400 CALIPERS ARE THE SHIZNUTS!!! i have them on my 1st Gen GS300 TOOO~~
Old 12-05-07, 09:09 AM
  #113
GS3.0
GS3.0's Avatar
Aren't the LS400 brakes a newer design compared to the Supra brakes? I believe they are larger, but at the same time lighter too. I dunno, i might be wrong.
Old 12-05-07, 12:26 PM
  #114
aliga
Former Sponsor
aliga's Avatar
they are newer, and lighter
Old 12-05-07, 03:47 PM
  #115
FinLIFE
FinLIFE's Avatar
I just ordered my calipers today..what do you guys use for rotors/pads? Im also thinking of upgrading to ss brake lines.
Old 12-05-07, 08:33 PM
  #116
exquisit
exquisit's Avatar
did anyone do a piston area calculation? isnt that the main reason why people upgrade?
this also ties into brake balance as if the piston area is larger/smaller then the balance to the rea will be thrown off
Old 12-05-07, 08:41 PM
  #117
GSteg
GSteg's Avatar
No one calculated piston area yet. I can if you like, but it would serve almost no use for us. Without knowing the master cylinder line pressure, we just have to go by what feels good . Brake bias will be off, but I doubt it will be off that much. Even the aftermarket BBK setups were designed around the OEM master cylinder and they are one step ahead of the LS400 setup. If anything, the LS400 fills in the blank between OEM and aftermarket BBK. TRD offers a BBK (supra) setup for our cars and I have no doubt that the piston area of the Supra calipers is more than the LS400's.
Old 12-05-07, 08:44 PM
  #118
GSteg
GSteg's Avatar
I'm going to go with brembo blanks and Akebono ProACT pads. I dont need a very aggressive bite that the axxis ultimate offers, and I certainly do not want the brake dust that comes along with it .
You might want to look into our new Brake vendor if you want something more aggressive.. I think he's selling some cryno'ed rotors (x-drilled and slotted) with Hawks pads for $299. Not sure if he has them for the LS400 though.
Old 12-05-07, 09:03 PM
  #119
Nosexnolex
Nosexnolex's Avatar
Do not buy drilled rotor since they will crack. I know from experience, if anything buy slotted, I used powerslot. You can buy the drilled rotor only if it was casted that way, not drilled after casting process. In addition, I used hawk before but went back to OEM pads since they provided better initial bite. Fade was a lot more with OEM so I got SS lines and went back to aftermarket pad, got every bit of air out of the system. .. Bite is so good that I am able to lock them up at 110MPH!
P.S. I'm using Motul Brake Fluid.
Old 12-05-07, 09:29 PM
  #120
GSteg
GSteg's Avatar
You are very correct on that! Cheap cross drilled will crack under high heat. But there are companies out there like brembo who offers cross-drilled rotors that are reliable. I never like cross-drilled on small rotors anyways. Looks weird to me.
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
