sway bars
Old 08-18-04, 12:30 PM
La400
La400's Avatar
Default sway bars
Just wondering,
I looked and saw a purple rear sway bar with yellow bushings, that look kinda new, also looked up front and front sway had new looking red bushings.
Is this correct for factory?
Thank for any input.
Tim
Old 08-18-04, 01:20 PM
rominl
exclusive matchup
rominl's Avatar
huh?! no, never heard of it before, who is it from? trd is either blue or white. daizen is red.
intrax?
Old 08-18-04, 01:25 PM
La400
La400's Avatar
Default sways
Hi Thanks for reply,
Rear one is PURPLE and 3/4" thick, high yellow bushing, looks new
Front is 1 and 1/8" thick and bright red bushings, I see a number of places on suspension where there is high yellow bushings.
Any idea of what factory size is?
Thanks,
Tim
Old 08-18-04, 01:51 PM
Neo
The One
Neo's Avatar
The Intrax ones are kind of purplish.
Old 08-18-04, 01:56 PM
La400
La400's Avatar
Default sways
With age is guess the purple could get darker, front not purple though. Took some pictures will post later, rear is connect to arms kinda strangely, but having no experience with these cars it could be set up that way, connects to arm at a odd angle.
Who knows when you buy used, have a Akimoto intake but don't know if ECU has been upgrades.
Thanks,
Later
Old 08-18-04, 02:39 PM
rominl
exclusive matchup
rominl's Avatar
botht he fronta dn rear sways on the GS they are attached to end links which is then connected to the suspension
Old 08-18-04, 05:00 PM
La400
La400's Avatar
Default pics rear and front
Let see if I can get these pics in, rear purple and front bushings look new. In rear pic see how the end is oddly bolted at angle to arm, seems it should be bolted flat.
Old 08-18-04, 05:02 PM
La400
La400's Avatar
Default rear view
did load rear view
Old 08-18-04, 08:00 PM
Neo
The One
Neo's Avatar
I don't know. The rears could be the Intrax. The fronts might be stock with polyurethane bushings.
Old 08-18-04, 08:27 PM
rominl
exclusive matchup
rominl's Avatar
yeah i have no idea too, if i have to guess iw ould be with neo
about the end links, it looks weird to me too
Old 08-19-04, 04:05 AM
La400
La400's Avatar
Default sways
Hi, thanks for imput,
Both links are connected the same way and are solid connections, bolt must be made that way, I am only guessing, sure leaves a fella wondering when it is going to fall off.
Old 08-19-04, 06:45 AM
joshoowa
joshoowa's Avatar
is this on ur car? how come you dont know whats going on with ur suspension, or did u buy ur car used?
i dont think the rear is Intrax, you provided a pix neo of an Intrax setup look at the rear sway it has another outward "bend" (2 curves on each side), while the one La400's car has only a normal shape one "bend" -- well thats if ur pix provided is the one for a GS. well i dont know Intrax uses yellow bushings too Ah oh well
Old 08-19-04, 07:03 AM
La400
La400's Avatar
Default sways
No,
purchased used 4 months ago, 95,000 miles, slowly going through it. Did all the items required at this milage plus some additional clean us and going over mechly. Everything sound and working correctly, just started looking at upgrades, without going full blown set ups.
Just in the discovery stages as to what is what, handles well, had a good run through some real curves with a newer corvette and he wasn't a happy camper that I gave him such a hard time.
Front bushing shot, actually does show well but is a copper outer core around the red bushing and it looks new.
Think it would do any good to redue everything, plus I am going to change the steering ECU, unless it has already been done, who knows.
Thanks,
Tim
Old 08-19-04, 09:49 AM
Neo
The One
Neo's Avatar
Good call. I was just going by colors. As for the pic, it is the one on RMM's site. I don't know if the pic is specific to the GS but they did sell a set for the GS.
Old 08-19-04, 09:50 AM
Neo
The One
Neo's Avatar
Default Re: sways
Thanks,
Tim
Unless the previous owner marked it, there would be no way to tell since the outer housing of the OEM and recalibrated ECU looks the same. Even the same part number.
PHML
Suspension and Brakes
129
08-02-18 09:29 AM
mrblister
08-23-17 12:16 PM
NEbiker10
12-18-11 11:40 PM
Wheel Dr
03-07-11 08:22 PM
Red Bully
09-06-08 04:42 PM
Quick Reply: sway bars
