Power steering fluid change on high miler
Old 03-26-17, 12:16 PM
anyoldiron
anyoldiron's Avatar
Default Power steering fluid change on high miler
The following 2 users liked this post by anyoldiron:
IanB2 (03-27-17), jasanders (04-26-17)
Old 03-28-17, 10:29 AM
LoneHiker
LoneHiker's Avatar
Ya I used this same process when I bought mine last April. The PS fluid turns black after a bunch of miles, this is the best way to get the old stuff out. My pump was beginning to make noise and this solved it.
Old 03-28-17, 02:37 PM
JLee50
JLee50's Avatar
My power steering groans a little bit on cold start - I wonder if this may help, or if I have to replace the pump.
Old 03-28-17, 05:14 PM
anyoldiron
anyoldiron's Avatar
[QUOTE=LoneHiker;9816911]Ya I used this same process when I bought mine last April. The PS fluid turns black after a bunch of miles, this is the best way to get the old stuff out. My pump was beginning to make noise and this solved it.[/QU
Old 03-29-17, 07:02 AM
chiph9
chiph9's Avatar
A fluid change is way cheaper than a new pump. Try it and see.
Chip H.
Old 03-29-17, 07:37 AM
anyoldiron
anyoldiron's Avatar
Chip H.
x2
Old 04-27-17, 11:25 AM
jasanders
jasanders's Avatar
Thanks for this post. I will definitely be doing this in the near future as I have the same issue that JLEE50 described.
When I cold start mine, I can hear the PS pump groan like 4 or 5 times, like it is trying to circulate the fluid. Also I hear it make the same noise randomly while driving. This could be also why I have a slight steering wheel shake. Will update once I complete the flush.
Old 04-27-17, 04:04 PM
470reasons
470reasons's Avatar
Good post anyoldiron! Your method is very good and I probably should be using it. I just started exchanging my PS fluid yesterday. I'm just sucking the old fluid out of of the reservoir and replacing it with fresh standard Toyota ATF (not WS). So far, three exchanges and I'm starting to see a little red. Man, that old fluid is nasty smelling and looking! Picked up a 'sucker' at Menard's for under $4.00. The sucker comes with a small hose that gets down to the bottom of the reservoir. Again, not as good as your method anyoldiron, but eventually the PS fluid should be pretty clean.
https://www.amazon.com/gp/product/B000G72U0K/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000G72U0K/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Old 04-27-17, 05:43 PM
JLee50
JLee50's Avatar
It's either my imagination, warmer outside temperatures, or mine is getting better.
Old 04-28-17, 07:35 AM
anyoldiron
anyoldiron's Avatar
[QUOTE=JLee50;9850397]It's either my imagination, warmer outside temperatures, or mine is getting better.[/QUO
RA40
Maintenance
21
02-18-16 06:10 AM
Daspyda
09-24-15 01:56 PM
Emilio253
06-22-10 11:17 PM
billj747
16
01-21-08 10:53 AM
phillipin
07-15-05 05:01 PM
Quick Reply: Power steering fluid change on high miler
