Aftermarket brake rotors - rust on inner edges
Old 02-19-17, 07:46 PM
Jesse23
Jesse23's Avatar
Default Aftermarket brake rotors - rust on inner edges
Apologise if this has been discussed before...
So I recently replaced my front brakes with DBA T2 rotors 2720S + Akebono pads ACT1118. The result is great - better initial bite, less dust and quiet.
However I've noticed rust on the inner edges (about 1cm) of the new rotors. My guess was that although the overall diameter is the same, the new rotors have more inner surface where the pads can never make contact with. I was told by both my mechanic and DBA that my guess was right and this is normal.
Have you guys had any experience or had the same issue on your cars? I understand this might be completely normal, but it just doesn't look good.
Thanks
Old 02-19-17, 08:01 PM
Sasnuke
Sasnuke's Avatar
Received 1,738 Likes on 1,371 Posts
From what you described it sounds normal.
The inner part of the pad will never get as close to the center of the rotor like the outer edge of the pad with the outer edge of the rotor.
Depending on the durability of the coating used on the "non-friction" part of the rotor, will depend on how long it resists rust...but eventually it will rust.
Old 02-19-17, 09:26 PM
Jesse23
Jesse23's Avatar
Thanks.
It just looks awful. If by any chance I get more exposed wheels in the future, it will look even worse...
Old 02-19-17, 09:34 PM
isfvss
isfvss's Avatar
Just take your wheels off and paint it with high temp black .
colenzae
HS 250h Model (2010-2012)
06-08-15 10:43 AM
Marexus
Suspension and Brakes
31
04-12-12 06:11 AM
BlkSapPrl7
11-03-10 06:25 AM
LexiGx470
GX - 1st Gen (2003-2009)
01-16-08 06:40 AM
Quick Reply: Aftermarket brake rotors - rust on inner edges
