Heat Still Blowing Cold after Thermostat replacement
Old 02-13-17, 01:26 PM
streetnick
streetnick's Avatar
Question Heat Still Blowing Cold after Thermostat replacement
Whats up guys, first post on here besides the introduction section. So I recently bought a 95 SC400, and one of the problems was that the car wouldn't warm up fully, and the heat was blowing cold.
So I thought it would be the thermostat to fix it all, and I was wrong. The car properly heats up now, but the heat still blows cold. I suspect its the heater core, but hope its not ;/
Any tips, suggestions, or pointing me towards the right thread would be appreciated.
Thanks again,
streetnick
Old 02-13-17, 03:36 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
Heat is very sensitive to air in the coolant.
Salim
Old 02-13-17, 03:39 PM
ttsport15
ttsport15's Avatar
Could be a bad switch
streetnick
streetnick's Avatar
Smile
Salim
Thank you. After searching the forum (like I should have first, sorry for wasting a post) Thats what I concluded. Im going to try tomorrow and I'll report back if I have any problems.
Old 02-25-17, 11:53 PM
tzxlyd
tzxlyd's Avatar
Streetnick,
I am curious about what you found as your problem -- I am having a similar problem.
Old 02-26-17, 01:40 AM
Zerodrag
Zerodrag's Avatar
Are you sure your heater control valve is functioning correctly? It's on the passenger side firewall, and it should move when you adjust the temp control ****. Mine was leaking and it would get stuck from the coolant residue.
Old 02-26-17, 05:08 PM
tzxlyd
tzxlyd's Avatar
I am not sure but I will check it when I get the car back -- I think I tried to do a by pass of it with a cheaper valve that goes on a ford. I believe there was a forum post about it that I tried to follow but I don't think that worked for me -- I may have to bite the bullet and by an OEM. My car is in the shop getting body work done so I cannot check it. When I get the car back I will check that -- I appreciate the reply. So I take it you either fixed the problem or replaced the valve?
Old 02-26-17, 08:16 PM
Zerodrag
Zerodrag's Avatar
I bought a used one off eBay for around $40-50 and just swapped it in. No need to buy a new one when you should be able to find one used either online or at a junkyard. I think they were the same for the 300s and 400s, but not 100% positive.
Old 03-02-17, 07:43 PM
tzxlyd
tzxlyd's Avatar
Zerodrag,
Thanks I will look on eBay.
Abernoots
03-06-18 07:54 AM
sailorpam
GS - 1st Gen (1993-1997)
02-14-14 07:04 PM
MattStarr
13
02-23-13 03:09 PM
nsx01
12-04-03 01:05 AM
Lexusnyc
05-14-03 07:31 PM
Quick Reply: Heat Still Blowing Cold after Thermostat replacement
