HID Bulb Replacement
Old 01-20-17, 02:08 PM
shvc1991
shvc1991's Avatar
Default HID Bulb Replacement
Has anyone removed and replaced their D4S bulbs? Just wondering how difficult it is without actually removing the bumper cover and headlight. Is it even possible?
Old 01-22-17, 12:11 PM
jollick
jollick's Avatar
Default 2013-2015 HID Headlight Bulb
No need to remove the bumper. It is very easy to replace.
This shows the HID bulb housing with the cover removed, I believe you twist the socket to be able to pull it out. See instruction and cautions.
This is the HID headlight housing with the cover on, it twists off.
Read this.
Old 01-26-17, 07:25 PM
shvc1991
shvc1991's Avatar
Thank you so much for you response. I was able to figure it out in the dark the other night. Haha. Extremely easy, but the driver's side was a bit of a squeeze for my hands.
Old 01-27-17, 06:54 AM
jollick
jollick's Avatar
I am glad it all worked out.
Old 01-27-17, 02:45 PM
Nohnv
Nohnv's Avatar
Are you replacing with stock bulbs or different ones?
Old 02-01-17, 12:35 PM
tcgandhi
tcgandhi's Avatar
Are these bulbs plug and play or is there some wiring install needed?
Which bulbs/kits are recommended?
Old 02-01-17, 05:00 PM
jollick
jollick's Avatar
You cannot simply change out a Halogen with a HID bulb. The sockets are different and the wiring may also be different.The lens might also be different.
Old 02-02-17, 03:52 PM
Brent1944
Brent1944's Avatar
Depends on the car.. I had a Pilot and added HID Low Beams ..plugged right in..Lens is made for Halogen yes.. but it worked amazingly well..Very bright..
Shinchan
01-11-24 06:50 PM
Cpartipilo
07-28-17 11:24 PM
fruson
IS F (2008-2014)
10-15-16 01:35 PM
kas4
04-06-12 03:08 PM
ISynerg350
07-28-10 10:27 PM
Quick Reply: HID Bulb Replacement
