Need HELP installing Tom's front lip !!!!!!!!!
Trying to install front lip and we have three big holes in front that do not line up with any holes in the body. Instructions are in Japanese . Anyone have any ideas .
ti it was mine...I would just make holes in those locations and use a bolt and washers( big ones ) and a nut ....which may require removing bumper cover....but u don't want to loose this at speed....its a nice lip
I took my bumper off and drilled 3 holes in my bumper to align with the 3 big holes in the front part of the lip. Then you you need to drill 2 smaller holes to the left and right of each big hole in the bumper to attach the metal bracket shown in diagram #2 of the first pic you posted.
Also, I would recommend taping off around where the edge of the TOMS lip will be. The edges of the lip are pretty sharp, and as you're test fitting/installing, may scratch your paint.
-R
Originally Posted by JDMV8
all that garage space...and decor. You're lucky man
Originally Posted by FNSSESPORT
I did exactly this, except I left the bumper on. It would be WAY easier removing the bumper to do this install. The LH and RH little metal brackets were easy to drill for, even with the bumper on. The centre bracket however, took me probably an hour, because space is tight. Also, if you have the headlight washers, watch out for the supply hose that runs along where you'll be drilling.
-R
-R
Originally Posted by ZaxF
I used 3 self tapping screws for those spots, similar to what Lexus uses with the built in washer, you can also drill a large hole and use a heavy duty plug similar to what is used to hold on the rear mud flap that sits in front of the back tire.
lmschuur
12-29-10 04:23 PM
