H&R 25mm DRM Spacers Installed W/ Pix
I only got 2 25mm spacers for my rear wheels. I have 19 x 8.5 all the way around with a very conservative offset (wheels were orginally from an IS), and the rear wheels were tucked in WAY to deep.
Here are pix of my car before the spacers:
Relativity measurement shot using my cell phone. Wheel to fender gap easily exceeds an inch and half. I will post comparison cell phone shots with the spacers in.
), socket wrench (10 mm if I recall correctly, I couldnt use the stock socket wrench cuz it had too big of a diameter to fit into my wheel lug nut holes), jack stands (cheap 2 ton stands from Pepboys), cleaner solution with rag (I just used Meguair's Quik Detailer), and the spacers. Sorry for the crap pix, I was just pointing and shooting as the sun was setting.
2.) You have to clean off all that corrosion so get a smooth surface so the spacers sit flush to the hub. I have a 99, and had a lot of rust around my hub.
3.) Carefully mount the spacer to your hub. I was AMAZED at how tightly they mounted in (this is a good thing). I couldnt just fit it on with my hands. I had to use a rubber malet (very gently) and gingerly banged it in (in a reciprocating star formation as to not damage the spacers, your any of your wheel assembly, and to get an even and flush mount to the hub. Once on, they didnt budge.
4.) Use the lug nuts they give you to tighten the spacer onto your hub. Again use the reciprocating star format as to give the spacers even and smooth fitting.
Looks: The rear fender gap is almost gone, but not QUITE flush. Not sure if I'm being a bit too picky or just have super high expectations, ya'll can judge for yourselves.
Vibrations: Non-existent. No vibrations at all. Took the car on the freeway just to make sure with the radio off and windows up. Took the GS smoothly to 120 mph with no difference. Seemed smoother actually, could be placebo though.
Handling: Drastically improved when taking corners at higher speeds. The wider stance definitely improved cornering. I think my EDFC/Tein CS V.2, Daizen sways and poly brushings helped a bit there as well.
Ride Quality: Exactly the same.
Pix:
Comparison directly behind rear fender shot:
Comparison fender gap cell phone shot:
I remember someone asked how the spacers look up close to the wheel. You cant even see them from a straight on shot. You can see them from the sides. They look clean and like part of the stock wheel assembly. Oh yea, and you get hella bbk clearance too!
Oh yea, I get to rotate my tires everyone.
Thats all folks!
As for the spacers, I bought them used in the wheel classified section from gdot (good lookin out homie
) for $100 shipped. Yea I'ma certified CL classified buying vulture
